Reply
Thread Tools View Mode
Old 20th Mar 2007, 22:37   #41
TapperSwe
Supermodder
TapperSwe's Avatar
TapperSwe has yet to learn the way of the Dremel
The UV effects on the brackets do look really nice , this is one of the moust different builds i have ever seen,waiting to see more.
Regards.
__________________
Build done:The Legacy of King Khufu:
http://forums.bit-tech.net/showthread.php?t=129157
Speakers Done:
http://forums.bit-tech.net/showthrea...129157&page=11
TapperSwe is offline   Reply With Quote
Old 26th Mar 2007, 19:33   #42
dacust
What's a Dremel?
dacust's Avatar
dacust has yet to learn the way of the Dremel
No progress, but parts coming in
Still waiting on parts.
Received:
  • 3/8" hose from Koolance. The hose I had was too bid OD to work with their fittings
  • 2nd HDD cooler
  • 2nd Harcano fan controller (for PC)
  • Mucho wire ties, sleeving, heat shrink, etc.
  • Bunch of UV and blue LEDs
On order:
  • Plexi tube for the reservoir (should be here this week)
Forgot to order:
  • 1/4" tubing for the PC (this won't hold up the project, though)
  • Yellow LED for the operations shack
I've done some more testing on the lighting effects, but nothing worth a photo. I'll be out of town a lot for the next coupla weeks, but hopefully, as sson as the Plexi tube gets here I'll have some time an evening or two to get something done.
__________________
-dan
My programs don't have bugs, they just develop random features.
WaterPlant worklog - in progress - Bit-Tech article - WaterPlant site - Home Page - PowerPlant PC - Designing
Don't worry about your english. This is an international forum. That's what makes it great. If I don't understand, I'll ask. Just MOD ON!
dacust is offline   Reply With Quote
Old 26th Mar 2007, 20:17   #43
Rocket733
Austerity - It's the only way
Rocket733's Avatar
Rocket733 has yet to learn the way of the Dremel
I like the industrial feel of this mod so far, looks very unique. So this is a prototype for the final industrial mod? Keep up the good work
Rocket733 is offline   Reply With Quote
Old 26th Mar 2007, 20:21   #44
DarkLord7854
I Mod, Therefore I Own
DarkLord7854's Avatar
DarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run CrysisDarkLord7854 can run Crysis
Neat idea! Though I don't get why you want to use blue dye as the UV light is already blue-ish, wouldn't you want to see the hoses?
Anyways, eager to see more of this
(I wonder if you can add like.. sparkle or somehing in the water so that you can see things whiz by inside the tubes)
__________________
Asus P9X79 Deluxe | i7 3930K | 2x Asus GTX760 | 3x OCZ Agility3 240GB SSD - 1x WB Black 1Tb | G.Skill Ripjaws Z 32GB DDR3-1866 | Creative XtremeGamer X-Fi | Thermaltake Level10GT
DarkLord7854 is offline   Reply With Quote
Old 26th Mar 2007, 20:23   #45
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
This project is just an excause for you to keep building with those things, isn't it? It's OK I guess many modders kept building with legos and erectors and what ever building sets for longer than other kids.. I guess?
Nice UV-effects there.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 26th Mar 2007, 21:04   #46
dacust
What's a Dremel?
dacust's Avatar
Yep. You got me there.
Actually, it just seemed like a good prototyping tool. Then as I got working on it, I liked the results and decided to make it a project of it's own.
I think the blue will make the tubes jump out at you. And since the wiring will be red and the data green (only the temp probe wires green in the WaterPlant) blue seemed the right color. But I'll experiment because you may be right. As to the sparkles, I like the idea, but I can't imagine anything that would work that wouldn't create a possible clogging problem. Any ideas out there?
Thanks. I'm having fun! The only reason the posts have slowed down is due to waiting on supplies. I'm still fired up about it. Should be new things worth photographing in about two weeks (I'll be out of town this weekend).
Again, thanks for the support and suggestions!
__________________
-dan
Old 26th Mar 2007, 21:50   #47
Jipa
Jipa's Avatar
Yeah it wasn't too hard to guess. I use those sometimes also.. for... prototyping
Looking forward. Atleast it's unique!
__________________
Old 26th Mar 2007, 22:16   #48
Skill3d
Multimodder
Skill3d has yet to learn the way of the Dremel
looks kinda steampunkish... it's very unique
Skill3d is offline   Reply With Quote
Old 26th Mar 2007, 23:08   #49
SlappKnutts
Modder
SlappKnutts's Avatar
SlappKnutts has yet to learn the way of the Dremel
This project puts a smile on my face! Man I played with an erector set when I was a kid, and it was my dads when he was a kid! Did your sets have any dates that you could see? As they can easily be over 50 years old! And now your putting them to work in a "modern toy"!
Fantastic!
SlappKnutts is offline   Reply With Quote
Old 26th Mar 2007, 23:17   #50
dacust
What's a Dremel?
dacust's Avatar
Fantastic!
No dates on them, but the one in the wood box is from the 30's. The others range from the 40's through the 60's. Since they are antiques, I'm not cutting or bending any parts. That's the reason some of the structure looks kinda strange or overdone. Only way I could make the parts fit.
I'm having a blast palying with some of my favorite toys. Erector sets and computers. How could it get any better?
And I still have a surprise or two in store....
__________________
-dan
Old 27th Mar 2007, 19:15   #51
dacust
What's a Dremel?
dacust's Avatar
Scanning back and looking at the photos, I remembered this comment, and it struck me that I see why you said that.
The photos you see are long exposures. In RL the parts don't show up as much and they don't look as blue. The UV blue water should show up very bright in contrast to all the rest. Looking at the UV photos, I can easily see why you would think it would get lost. Interestingly, now that I have the tubing I am actually going to use, it is slightly UV reactive, a pure blue.
But as I said first time I responded to you, once it's done I may re-consider.
__________________
-dan
Old 27th Mar 2007, 20:00   #52
DarkLord7854
Ah, that's why
Could you snap a pic of what the tubes look like without the long exposure?
Your mod reminds me of those old KNEX (I think that was the name) I used to have, where you could build a buncha stuff from metal parts, it was like legos, but in metal
__________________
Old 27th Mar 2007, 20:13   #53
dacust
What's a Dremel?
dacust's Avatar
Sure thing. This evening I'll get a shot where you can see it a little more like it will really look. It'll be greenish/yellow tube instead of blue, but it should give the idea. I'll see how I can get it, not sure my digital can do it (2 stops adjustment?), but I might get it with the 4x5 with polaroid film and scan that in. If not, then on the 35mm, but you'll have to wait for developing...
__________________
-dan
Old 27th Mar 2007, 20:18   #54
DarkLord7854
If the digital doesn't work then don't worry, don't go wasting film
Are you using UV cathode(s)? Or bulb(s)?
__________________
Old 27th Mar 2007, 21:10   #55
dacust
What's a Dremel?
dacust's Avatar
Originally Posted by Meltdown
Does that swiftech pump take the same size tubing as the Asetek?
Yes. 3/8". It's a Swiftech MCP350. 92.4 GPH. $80 on this side of the pond.
You seem to have a fair mixture of component styles in there. Is that how Erector set components have evolved over time?
Yep. They changed a lot. I have used the girders only from the 1920's and 1930's set (with the triangular holes). The large base plates are from 30's-40's. The red parts with all 4 sides bent up are the newest, from the 60's probably. The red axle supports are from several eras. An ardent Erector afficianado might cringe at the mixture, but if so, they can go back to the Erector forums and complain.
You can see from my sig below how my Asetek experience is going... I figure, every time I talk someone out of buying one, it's worth $1 to me. I've scored 1 so far. And what the heck, we'll count each 1000 views of this log as $1. That's a total of $4 so far. That leaves 186 to go to get my money's worth (pump+LCD). If they give me a replacement, then I can deduct whatever I get for it on eBay.
__________________
-dan
Old 28th Mar 2007, 02:24   #56
dacust
What's a Dremel?
dacust's Avatar
Answer
Thanks. I had decided it wasn't worth dragging out the equipment anyway. Without water in the tubes it won't really show what we wanted to see anyway.
I'm using UV LEDs. In the tower it'll be two modified sticks running off a controller. For the rest, it'll be individually strategically placed UV LEDs. And probably some blue LEDs under the platform.
__________________
-dan
Old 28th Mar 2007, 02:46   #57
dacust
What's a Dremel?
dacust's Avatar
Update 2007/03/27 - pump installation & some plumbing
OK, I'm starting stuff now that I can document the actual process a little more. So this update is more pics, less talk.
The pump mount:
2272x1704
Added some self-adhesive foam sound deadening from FrozenCPU
2272x1704
Using layers of the same stuff, built up blocks to hold the pump in place.
2272x1704
You can see the blocks a little better from this angle.
2272x1704
The pump fits in snugly.
2272x1704
So snug I can pick it up by the pump alone.
2272x1704
The the top is put on.
2272x1704
Here you can see how far up the foam comes.
2272x1704
And then it's bolted in place.
2272x1704
I started the plumbing. Before anyone says anything. I KNOW the right angle bends are bad for performance, but for this theme, I thought it was necessary. If it causes too much back-pressure, I'll add another identical pump inside the PC. So there will be about the same number of turns and equipment between each pump.
2272x1704
I can't really do any more until the plexi tube gets here. They tell me it's shipped, so I should be able to start the tower next week.
So anybody got advise on how to rig the plexi tube? Like the best way to install barbs in the side? And how to seal one end and put a filler cap on the other?
My plan is to get some thick plexi and cut a circle the size of the O.D. and rabbit to the I.D. and seal it in with silicone. In the top one, make a hole for a fill port, like maybe the one from Danger Den.
The barbs I'm less clear on. I can do the hole and take the elbows I have, cut it down and silicone it in place, but that won't hold up when putting the tubing on. Seems like I need something that screws into a backing ring. But if it's made for a flat surface, the 1" I.D. tube will cause a problem.
__________________
-dan
Old 28th Mar 2007, 10:15   #58
TapperSwe
Supermodder
TapperSwe's Avatar
The pump houseing/case looks neat.
Regarding watercooling i cant help u cuz i know so litle about it.
__________________
Speakers Done:
Old 28th Mar 2007, 14:06   #59
jokkos
too busy to mod *sigh*
jokkos's Avatar
jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.
good solution for the pump.
With respect to the watercooling, you should be fine with those 90. It will give a lower flow rate, but that's not a big problem.
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 30th Mar 2007, 05:07   #60
dacust
What's a Dremel?
dacust's Avatar
Update 29/03/2007 - Plumbing and plexi - w/pics
I got the plexi tubing today. It's going to work great, but the light sticks I have will not fit in like they are. I'll have to remove the lights from the plastic tube they are in, insulate the back and then they'll fit. I also played around with some ideas for running the wires to the lights, but nothing to show for it. All I have to show new is where I neatened up some of the plumbing and took some shots from a better vantage point.
Here's a close-up of the finished part of the plumbing.
2272x1704
A UV shot where you can see the internal structure a little better.
2272x1704
This is a little closer to what it looks like in RL. As I mentioned before, the tubing is slightly UV reactive. When the blue UV dyed water is in there, I think it will really pop out. Also, there will be several of the orange lines running around as well as one set of green.
2272x1704
It'll probably be next weekend before I get working on this again. Then it'll be time to build the reservoir. After that the rest of the plumbing will be quick. Last big job will be the wiring.
__________________
-dan
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
