BAD_WORK_UNIT
Discussion in 'bit-tech Folding Team' started by Qazax, 12 Nov 2015.
  1. Qazax
    Qazax Fap fap fap
    20 Aug 2012
    Hi All,
    I checked my logging on the folding client and saw the following:
    Code:
    13:29:04:ERROR:WU04:FS00:Exception: Could not get an assignment
    ******************************* Date: 2015-11-06 *******************************
    22:02:46:WU03:FS01:0x21:ERROR:Discrepancy: Forces are blowing up! 3732 2
    22:02:47:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
    ******************************* Date: 2015-11-07 *******************************
    00:59:45:WU01:FS01:0x21:ERROR:Potential energy error of 1320.95, threshold of 10
    00:59:45:WU01:FS01:0x21:ERROR:Reference Potential Energy: -587951 | Given Potential Energy: -586630
    00:59:46:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
    ******************************* Date: 2015-11-08 *******************************
    ******************************* Date: 2015-11-09 *******************************
    20:58:55:WU01:FS02:0x21:ERROR:Potential energy error of 256.067, threshold of 10
    20:58:55:WU01:FS02:0x21:ERROR:Reference Potential Energy: -587260 | Given Potential Energy: -587004
    20:58:56:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
    ******************************* Date: 2015-11-10 *******************************
    20:46:47:WU02:FS02:0x21:ERROR:Max Retries Reached
    20:46:48:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
    ******************************* Date: 2015-11-11 *******************************
    ******************************* Date: 2015-11-12 *******************************
    Should I be worried? I know one of my GX 970's is running at 83 degrees and not fully turboing as it is next to the second card (which is running mid 60 degrees and fully turboing) but apart from that it seems to be running ok.
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    When it says "Forces are blowing up!", this is a reasonable sign it is probably the WU at fault and not the GPU.
  3. Qazax
    Qazax Fap fap fap
    20 Aug 2012
    Thanks DocJonz, I was a little worried the hotter card may have been throwing some issues. Will keep an eye on it and attempt to remedy the airflow situation.
