Buy & Sell?
Discussion in 'Feedback & Suggestions' started by NoobNeb, 24 Apr 2016.
  1. NoobNeb
    NoobNeb Enthusiastic Lurker
    14 Nov 2011
    Hi guys, I've been away for about 18 months so I just wanted to check does bittech still have a buy & sell? Do I just not have access cause I've been inactive?
    Cheers
  2. Arboreal
    21 Jan 2011
    Yes it does, some time in the recent past the requirements for access to the Marketplace were changed.
    IIRC, now it's 150 posts and signed up for 3 months.
    so, you've been on long enough, but need more (non spamming :nono:) posts to get over the bar
    HTH
    NoobNeb likes this.
  3. NoobNeb
    14 Nov 2011
    Figured it was something like that, thanks for the answer!
    When I originally signed up I was 16 and had no notion of forum etiquette so if some of my posts were spammy before they won't be now.
  4. GeorgeK
    18 Sep 2010
    Yes - the requirement was upped to 150 posts and 3 months membership to stop newbies joining specifically to access the market place, spamming their way to 75 (at least I think it was 75) posts and then waiting until the 30 days was up
  5. f001
    f001 What's a Dremel?
    24 Nov 2002
    I haven't been on for a year and wondered the same! Been joined for 14 years with only 137 posts how lame am I?
    GaryP likes this.
  6. GeorgeK
    18 Sep 2010
    That's an impressively low posts-per-day rate :)
  7. Broadwater06
    Broadwater06 Minimodder
    10 Apr 2016
    New member here. This is the first I hear about buy and sell. So after 150 posts and 3 months I can (not just ebay) come here for buying and selling? Where is it?
  8. Shirty
    18 Apr 1982
    Once you've met the requirements the marketplace will become visible to you.
  9. Broadwater06
    10 Apr 2016
    Ok thanks. A long way to go for me.
  10. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Thats worth a rep bomb 'Tel' style !
  11. f001
    24 Nov 2002
    I have no idea if that's a good or bad thing!
    I've been looking at some modding logs and christ! things have moved on from when I cut a hole for a window and a chimney fan and thought it was cool!
    B1GBUD likes this.
