Watercooling Compression Fittings
Discussion in 'Hardware' started by b1g-d0g, 3 Jul 2013.
  1. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    3\8" ID - 5\8" OD (10-16mm)
    Or
    3\8" ID - 1\2" OD (10-13mm)
    This will be my setup
    Asus Rampage IV Extreme
    Koolance RP-452X2 Dual 5.25 Rev 2.0
    Koolance PMP-450 High Flow Pump : PMP-450
    Cpu block not sure what one to get?
    EK FB KIT RE4 CSQ Motherboard Waterblock Acetal
    EVGA Hydro Copper Waterblock for GTX 680 Classified
    Alphacool NexXxos XT45 360mm Triple Radiator
    Alphacool NexXxos XT45 480mm Quad Radiator
    Motherboard and cpu will have 90 Degree Rotary Fitting`s to cut down on the clutter
  2. Parge
    16 Jul 2010
    Personally I'd go with 3\8" ID - 1\2" OD (10-13mm) - they are slightly more common so should be easier to get hold of in the future if you need to expand your loop
  3. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Just gonna say I'm madly unimpressed with koolance equipment, I've had 3 blocks that all deteriorated on the insides filling my loops with crap and several bungs that also deteriorated and leaked everywhere, I'll never ever use koolance again.
    I'd stick with other brands, ek, phobya , alpha cool etc
    Cpu block I'd go with a swiftech
    Sent from my GT-I9505 using Tapatalk 2
  4. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    I like the look of the swiftech fittings.
  5. Big Elf
    23 Apr 2009
    I've used 3/8"ID, 1/2"OD and for a simple loop they're fine. I prefer 3/8"ID, 5/8"OD though as you get a better bend radius without kinking compared to the smaller size.
    XSPC Raystorm blocks have good cooling performance with less restriction than many other blocks.
    Swiftech compressions are good, the silver finish ones have a layer of chrome so have a bright shiny finish similar to Bitspower.
