News Nvidia launches Pick Your Path game bundle
Discussion in 'Article Discussion' started by Gareth Halfacree, 5 Nov 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    So if i buy a top end graphics card i get to play a game at 30FPS, the same 30FPS that i get on a console with much lower spec hardware, and price (for the whole PC)
    I know one is made by Nvidia and the other by AMD, but are the differences in hardware and graphics so massive that buying a card that cost almost the same as a console mean it's wasted money.
  3. rollo
    rollo Modder
    16 May 2008
    If you cared enough about costs would you be in the PC gaming scene anyway? I know I would not be theres not enough exclusive titles to warrant the investment required to play them these days.
    Oculus Rift is Cheaper than the hardware required to run a game using it. Once the Consumer version goes live those requirements will double. Its target is what 75-90fps at the 2560 resolution good luck with that in a modern game with high settings on a single gpu. ( OR does not really work with sli or cfx yet)
    Or are you more concerned about the 30fps lock which is not the first pc game to be locked at 30fps. The Crew has similar lock from what I noticed in the beta. As have the last 3 need for speed games.
  4. Corky42
    30 Oct 2012
    I'm concerned that spending more money doesn't get you anything better, normally that's the way things work.
  5. Shirty
    18 Apr 1982
    I suspect that if the framerate runs at exactly 30fps, with perfectly even frame-times, then the experience will be fine for all but the most mutant of gamers. You know, the ones who have evolved beyond normal optical function owing to years of playing Quake and CS on absurdly overpowered hardware.
  6. SimoomiZ
    SimoomiZ What's a Dremel?
    2 Feb 2008
    Gameworks :(
