I bought an xbox one recently and want to have the sound play through my studio monitors (jbl lsr308) through my sound card (ASUS Xonar Essence ST). Not quite sure how to go about this: Speaker Inputs (per speaker): 1 x XLR, 1 x TRS Balanced xbox one outputs: hdmi, optical Sound card Line In: Yes Line Out: Front R / Front L, Headphone out SPDIF Out: High-bandwidth Coaxial/TOS-Link combo port MIC In: Yes
Just wondering - why do you want to run via your sound card? Wouldn't it be easier just to go direct into the monitors? You'd probably be best trying to locate a cheap optical -> RCA converter (I know CYP make them, like this, and then just going from RCA to 6.5mm jack (unbalanced). Of course - you can go all out and get a balanced out DAC, but that depends on budget
Perhaps you might find a cheap little receiver which you can use as an input switcher and preamp. Otherwise I suppose the easiest/cheapest solution would to buy a basic dac with optical in and rca out. Plug the analogue out to your soundcard line in and place it in listen mode.
I do have a receiver I can use. I think it is fairly recent with hdmi, optical, etc but it uses speaker wire and not the plugs.
No dice here, as the monitors are active. Does the receiver have pre-outs? If it does, there's your winner. XBOX -> HDMI -> Receiver -> Pre-out L&R -> RCA -> Unbalanced 6.5mm jack -> monitors In answer to your other question, running through the sound card is a bit redundant in terms of improving sound quality, to my mind.
