Case Mod - In Progress Full Steam Spacemashine --- final pics
Discussion in 'Project Logs' started by flix, 1 Sep 2014.
  1. flix
    flix Minimodder
    5 Aug 2009
    Hey guys, I want to share my latest project with you
    This project is based on a BitFenix Phenom which was modded during a contest at the german forum named Hardwareluxx.
    The hardware:
    - AMD 7850K
    - MSI 88XM Gaming
    - MSI 280X Gaming
    - Corsair Vengance Pro 2133
    - Plextor 128GB
    - Superflower 550W
    ideas:
    After doing some clean and simple mods, I wanted to create something conspicuous.
    The first Ideas were drawn very fast. :)
    The materials I used in this mod are aluminium and acryl, so nothing special. ;)
    After I got the first materials I started modding. :)
    I think this UV-active Acryl looks very cool, what do you think?
    The first big challenge was to cut the AcrylTube (OD 120mm) because I dont really have the right tools to cut... so the first cut failed...
    I tried it by using this saw:
    It worked! :dremel:
    After grinding it with some rough sandpaper the surface looked much better.
    After that the paper got finer and finer and it began to look quite well, it's getting smooth :)
    So I cutted some UV acryl...
    ...and glued it on the polished tubes.
    I used Acryfix
    finished glueing :)
    After drying for 24h I milled it to be flush with the tube.
    Next big challange:
    How to get the tubes into each other?
    With a lot of force :dremel::wallbash:
    The surface wasn't nice after hammering this parts so I need to file it down.
    The last step was to give the edges some radius. I also used my OF-1010 for that (by the way, nice tool :) )
    In the dark or rather under UV light:
    I hope you liked my first update, the next one is coming soon.
    See ya:thumb:
    Waynio likes this.
  2. Nexxo
    23 Oct 2001
    Now that's what I like. No long preamble, no long list of parts, no pictures of boxes; just dive-right-in hard-core modding, bitches!
    Furball Zen and Vetalar like this.
  3. morgansk
    morgansk I've got wood
    12 Jan 2013
    Oooh, loving that ring, nice work!
  4. kuala
    kuala What's a Dremel?
    24 Jun 2014
    Haha. Not wasting any time there are you ;)
    Very nice finish on the ring!
  5. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    I will follow this, looks very nice
  6. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Don't think I have seen someone so complimented on the finish of their ring. :D
    Nice job :thumbup:
    Sent from my Nexus 5 using Tapatalk 2
  7. leonetu
    leonetu What's a Dremel?
    29 Oct 2013
    Very nice first salvo. That ring looks great!
  8. amagriva
    amagriva Minimodder
    13 Jun 2009
    the chantilly lace worklog...
    nice hardcore hammered ring, it will rule them all! MUAHAHAHAA! whodeva...
  9. flix
    flix Minimodder
    5 Aug 2009
    Wow guys, thank you a lot :rock:
    I continiued with the fan. It wasnt easy to find one which fitted into the tube.... after killing 2 fans, the third one fits. I use some BitFenix Spectre Pro without the frame.
    I need to center the fan 100%, otherwise it will abrade ...
    Second Tube nearly done:
    Furball Zen likes this.
  10. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    INCREDIBLE! Thats the only word I can find for those fan rings:D
    I WANT them:D
  11. mitch311
    mitch311 What's a Dremel?
    10 Feb 2012
    wow, just wow. :jawdrop:
  12. kuala
    24 Jun 2014
    Those look ****ing awesome!
    This should be a log to remember!
  13. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Good to see this build here too Flix, I've seen the result and I'm gonna enjoy the show :)
  14. Darwing
    Darwing What's a Dremel?
    9 Apr 2014
    I don't know where people come up with this stuff! What is your day job? That is a work of art even to just create something like that :)
  15. phinix
    phinix RIP Waynio...
    28 Apr 2006
    HOLY SMOKES! That is what I call modding:rock:
    Very nice job, man:thumb:
  16. Bad Fenny
    Bad Fenny What's a Dremel?
    20 Aug 2014
    Very nice . . . love those rings :rock:
    Cheers
    Fen
  17. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Thank GOD. Right? :)
    Im glad the move is toward hating those types too...
    Glad you found words cause i had NO hope for this till i saw the finished result. Then i was like
    :jawdrop: :jawdrop: :jawdrop::jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
  18. flix
    flix Minimodder
    5 Aug 2009
    :eeek: :blush: :jawdrop:
    Thank you guys. :clap:
    But now lets start some serious modding on the case. :dremel:
    I've started by disassembleing the case, that was very easy, good job BitFenix :thumb:
    Nearly every part is just screwed
    Couse of the new hardware layout I wanted to have, I need to tranfer the motherboard tray. So I drilled out the rivets.
    To put everything together again, i needed a new backplate.
    I need to cut some aluminium sheets:
    And marked some cutting lines
    Drilled some holes for inserting the saw:
    But where to mount the new backplate?
    At first the old one has to go. So I take the jigsaw and removed the back of the case.
    To get a nice fitting of the sidepanels I have to make some cuttings.
    End of the Day: sticked everything together
    That it for now :rock:
  19. flix
    flix Minimodder
    5 Aug 2009
    And it goes on...
    At first I taped some therads, I used the following tool for that. I dont know the english word ^^ in german its "Nietmutternzange"
    8 threads later the plate could be mounted
    First test match of the hardware.
    the planned 280X wouldnt fit that easy... its 2 cm more wide than a reference graphics card...
    See you :rock:
  20. Cheapskate
    13 May 2007
    :thumb: Fiddy stars! Lovely way to start a project.
