Storage SATA III on SATA II Mobo
Discussion in 'Hardware' started by Bituser, 14 Oct 2011.
  1. Bituser
    Bituser 64 Gigglebytes
    13 Aug 2011
    Hi,
    I have a motherboard which only supports SATA II and I am going to get a 1tb HDD. Almost all of the HDDs appear to be SATA III nowadays. If I purchase a SATA III HDD will it be throttled to 3gb/s or will it just not work? Also, if you have any recommendations please post them. I am looking for the fastest speed at 1tb SATA.
    Thanks.
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    It will be throttled to Sata II speed, although a standard platter HDD will not be able to saturate a Sata II or III connection. You would need a raid array for that.
    For the fastest - look at Samsung F3 or F4, or the Western Digital Black series.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Sata III for HDD's is a gimic I am afraid, HDD's can't saturate sata 2 let alone get near sata 3.
    You only need to worry about sata 3 if your are looking at getting an SSD really
  4. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    I'm no longer sure on which is the fastest 1tb drive, used to be the Samsung f3 would be recommended round here.
    A sata 3 drive will just run at sata 2 speeds and with a hdd you won't see any difference.
  5. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    SATA1/2/3 are meant to be interoperable. In my experience it depends on the drive/disk controller combination. Some drives have jumpers that allow you to force the drive to a particular SATA version which seems to always work.
  6. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Hard drives can not take advantage of sata III so the connection is a gimmick. Just get the best/cheapest 1TB you can find that is reputable.
  7. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
