Graphics Gigbyte GTX 460 1GB Owners Unite!
Discussion in 'Hardware' started by Blogins, 9 Aug 2010.
  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Do any of you guys and gals have this card?
    After first hand experience of the terrible Palit Sonic GTX 460 I quickly changed it for this Gigabyte model and boy am I ever glad. The build quality is first class, no way can Palit compete with this. Temperatures are good, around the 70 - 75 mark (South facing room, very hot in the summer anyway!) under very heavy load (Looking at you FurMark) and the fans, can't hear them at all! Probably the most perfect graphics card I have ever played with. Nice little extra touches as well, including dust covers for the two DVI plugs and another for the SLI connector. Mini HDMI to full HDMI adapter included in the package as well.
    I'm well chuffed, would also be interested to hear if you guys have overclocked this beauty :thumb:
  2. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Gonna see how the mafia 2 demo runs on my comp, I suspect I need a new card and it's a toss up between this and a gainward one, dual fans look good for cooling when ocing, I use headphones when gaming so noise isn't that much of an issue, would be hoping to see 850 to 900 on the core :p
  3. Blogins
    3 Aug 2010
    From my research the Gainward is much the same as the Palit in design. They both lack VRM heatsinks and have a terrible fan. Something I neglected to mention above was that the Palit Sonic (NOT PLATINUM) lacks heatpipes. Simply an aluminium block and a fan, that's how sophisticated the Palit cooling was and the reason I sent it back! I can not over state how well the Gigabyte card is made in comparison. Have not tried overclocking yet but I am certain it will handle temperatures way better than the Palit which actually hit 90 at one point during my brief ownership of that horrible card!
  4. mkb
    mkb Minimodder
    2 May 2010
    My 2 Gigabytes arrive on Friday, I hope they are as awesome as you say ^^
  5. Blogins
    3 Aug 2010
    Replacing the EVGA GTX 460 SLI setup in your signature?
    The whole Gigabyte package is quality rest assured! You going for the 1GB version I assume?
  6. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    These are words I don't want to hear - the Gainward and Palits are the only shorty GTX460s and I need one less than 19cm for my mITX build. Is this the kind of problem that I can fix with a custom cooler, or do they run deeper than poor cooling?
  7. Blogins
    3 Aug 2010
    From personal experience the Palit Sonic is horrible. If you have to buy one then get the higher specification such as the Palit Sonic Platinum. As far as my knowledge goes that is the one that has a heatpipe design which should curtail temps better than a solid aluminum block alone! I believe the Gainward specification you'd be looking for is the GLH (Goes Like Hell). However the fan is the same on all models and when it ramps up you will hear it!
    I did try a custom cooler myself with a Zalman 950, but alas it didn't work out! Temps just kept going up because the contact point did not fully cover the GPU. Have heard of people using an Arctic Freezer CPU cooler on these cards but it sounds like too much hassle to me.
  8. mkb
    mkb Minimodder
    2 May 2010
    yea I sent back my EVGA's and ordered some Gigagbyte's instead. They will be the 1gig flavour too ^^
  9. mikezero
    mikezero What's a Dremel?
    9 Dec 2009
    Where did you order your 2 Giga's from mkb? Scan, Dabs or Ebuyer?
  10. mkb
    mkb Minimodder
    2 May 2010
    ebuyer in the end, worked out the cheapest.
  11. Blogins
    3 Aug 2010
    Just wanted to add a little information here.
    Been gaming for the past hour on my single Gigabyte GTX 460 and logged a maximum temperature of 65!
  12. techhead
    techhead Minimodder
    17 Jul 2010
    I all so had 2 palit 460 sonic platinum in a week both of them had dvi problems and the second one had a bad fan bearing as well
    Then i got a nice gigabyte 1gb
  13. PureSilver
    16 Dec 2008
    F***. I'll have to keep my fingers crossed a reputable brand comes out with a short version (I know Asus did shorty 5770s), otherwise I'll have to buy a Palit Sonic/Gainward GLH secondhand and do some cooler replacement. D'you reckon I could cool a GTX460 and an i7 860 on a single 140mm rad?
  14. IckesTheSane
    IckesTheSane What's a Dremel?
    15 Apr 2009
    I'm very pleased with this card. Cool, silent*. Very noticeable improvement from my 7900 (yeah, really). Great card.
    Except for one thing:
    Just for fun, I installed the Folding@home GPU client after reading the article reviewing the cards. I wasn't planning on Folding with it, but thought it might be a good way to help keep my room a little warmer in the winter. As soon as the client launches and it actually starts crunching numbers, there's a very noticeable, VERY ANNOYING high pitched whining sound. I immediately close the client, thinking my computer is going to explode, and the whining stops.
    I did a bit of digging, and found that this could be the case in maybe 30-40% of new higher end graphics cards. Making it "normal." Suggestions to 'fix' it included using a headset to game with, or turning the fans up on the card. Not because the card is getting to hot, but to drown the sound out. Really?
    Now I skipped a fair number of generations of cards going from a 7900 to this, but has this really become common? Is it never mentioned in any reviews because it's just a given?
    Anyway, now I'm starting to vent, which wasn't my intent. So, I'll just ask if anyone else has run into this? With this card, or with another?
  15. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I keep wondering how much of an upgrade this card would be over my 4870, and whether it's worth it...
  16. PureSilver
    16 Dec 2008
    It's a byproduct of NVIDIA's decision to use analogue power hardware instead of digital. AFAIK (I'm not an AMD owner) ATI 'cards don't whine, because they use newer digital power management systems, but NVIDIA's reference designs persist with analogue. As a result, especially under high initial load (when ramping up a game, or F@H, for example), you get high-frequency vibration which you can hear as a high-pitched whine. My GTX-280 whines for about ten seconds as graphics-intensive games load; it may well be that yours will stop after a short period too...
  17. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    My 5850 does it too, drives me up the wall as it's by far the loudest thing in my system when I'm gaming and the whole reason I went watercooling was to make it silent. I was mulling over moving to Nvidia as I hadn't heard any reports of it on the Fermi cards.
    Don't know if anyone can confirm if this is true or not?
  18. rojo
    rojo What's a Dremel?
    28 Aug 2007
    I have 2 Zotac 470's and I don't have any issues with a whining sound from either card.
    Where as the 295 card I have has this whine coming from it also.
  19. Teelzebub
    27 Nov 2009
    Doesn't happen to mine even when running the heaven benchmark.
  20. mikezero
    9 Dec 2009
