Modding Best precision screw driver set?
Discussion in 'Modding' started by Yaka, 26 Jan 2013.
    Yaka Multimodder
    26 Jun 2005
    So I lent some one my old and and much loved snap-on set, which was lost/nicked:( and I need a replacement are the wera kompact series any good or is there another brand thats better?
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Depends on your budget. Stanley area a good compromise between price and quality
    Yaka likes this.
  3. craigp84
    craigp84 What's a Dremel?
    28 Oct 2009
    The draper 'expert' ones (definitely not the regular draper ones!) are top notch. I bought a set around 4 years ago and they've never chewed up a screw head yet.
    Used primarily on tiny screw heads on RC Heli's and planes. The planes especially tend to be cheap tat from china (hey, I crash too much!) so their screws are normally silver painted butter. To not strip 'em is a serious achievement!
    Yaka likes this.
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    :thumb:
    look at the FatMax they nice weight and comfortable my box has flats, Pozi, Phillips and even some torx all are great to use not had one problem
    Yaka likes this.
  5. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Haupa make some very good screwdrivers. My dad has a Wera driver set uses for control panels, with the replacement bottoms that push fit into the base and one of the shafts locked into the base, so now its only good as a terminal screwdriver lol.
  6. Yaka
    Yaka Multimodder
    26 Jun 2005
    Well the choice has been made for me the guy that borrowed and lost them is replacing them with ther wera set hopefully they will be last me as
    Long as the snap on ones
  7. Xir
    Xir Modder
    26 Apr 2006
    As long as you don't use the Custom-PC Free 26-piece Toolkit :D
  8. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    If you decide not to get the Wera drivers - which are excellent - Wiha is another great option.
  9. Yaka
    Yaka Multimodder
    26 Jun 2005
    He got me different wera driver and bits that were big and had no tiny precision bits. In the end I got a draper precision kit.
    Was shocked to find how much similar snap on ones would cost now. but they rock solid and never chewed up
  10. JoshH
    JoshH What's a Dremel?
    19 May 2012
    I've got a set of Beta tools precision screwdrivers, can't recommend them enough.
  11. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    http://www.maplin.co.uk/33-piece-precision-screwdriver-set-48941
    I got that one in the top picture - how sure why there is two different images but its the top one I'd recommend. Had it for about 6-7 year and never damaged any bit, no tips breaking etc. I managed to drop on it at £9.99 in-store so bargin too. Use mine mostly for electrical items like laptop repairs etc.
