Peripherals USB Port Alternatives?
Discussion in 'Hardware' started by rieh, 19 Nov 2011.
  1. rieh
    rieh What's a Dremel?
    23 Jun 2011
    Hullo!
    Basically, my issue is that the USB ports on my laptop are physically incapable of working (due to an error on the part of a user of the laptop), and the connectors on the mobo are too close together for me to solder replacement ports on. I also can't afford a new motherboard right now. It's an Acer Aspire 5532 running Windows 7 Home Premium.
    The goal is to use another port, or my home network, to control a USB device, such as a flash drive, mouse, webcam, and/or USB hub. I have an SD port on the laptop. I also have a single 3.5mm audio jack for a microphone, and an ethernet line-in port.
    I've looked around to see if there's something to allow me to plug a USB device into an SD port, but the only thing I've found appears to support storage media, nothing else.
    Does anyone have any ideas, and if so, what are they?
    Thanks!
  2. flaming_goat
    flaming_goat What's a Dremel?
    24 Sep 2009
  3. rieh
    23 Jun 2011
