PSU What PSU to buy?
Discussion in 'Hardware' started by cookie! nom nom, 22 Oct 2012.
  1. cookie! nom nom
    cookie! nom nom Minimodder
    27 Apr 2012
  2. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
  3. Sviatoslav
    Sviatoslav What's a Dremel?
    3 Mar 2012
  4. narwen
    narwen narwen
    6 Aug 2010
    you need a 8 pci-e power connector
    the Pure Power L8 630W CM is a good psu
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  6. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    I'm not so sure of that... My current build (A bit last generation) Of a Phenom 2 X6, 6970, Sivlerstone FT02, and a few other bits and bobs, draws 550W at peak. Whilst I do think that generally PSU capacity is often overdone, I'd suggest 600W-800W for a high end single GPU build.
    Still leaves space to upgrade to more later.
    So my suggestion would be a: http://www.scan.co.uk/products/650w...ified-85-efficiency-140mm-fan-5-year-warranty
    My 4 year old OCZ power supply is still going well, and not a hint of coil whine. They seem to make good stuff.
    Whilst it's not Gold rated, that seldom makes a difference. I also think a 450W would be at a higher load, and therefore less efficient, ie- Gold 450W at 95% capacity is going to be less efficient than a 650W at 75%.
  7. mm vr
    18 Nov 2007
    Really? How did you measure that? The reviews linked in the other thread show that overclocked high end systems pull 350-400W on full load.
    Note that idle numbers are much less, and a computer will idle most of the time.
    Efficiency only drops a couple percent at most between 75% and 100% load.
