Other Video conversion
Discussion in 'Software' started by icutebluezone, 5 Nov 2008.
  1. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi there I have a RMVB video file. Im wanting to convert it to AVI.
    I have DrdivX and Cucusoft Video Converter and also Real Alternative plus codec pack installed. But still cannot convert it what do i need to use and free software would be best.
    Also the video does work.
    Thanks
  2. icutebluezone
    6 Aug 2007
    Any one no?
  3. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Xilisoft has a great video converter, but not sure if the free version will be able to convert it or not... Any possibility of importing the video into a video editing program, than just re-rendering the movie / saving it as a different format?
  4. icutebluezone
    6 Aug 2007
    Thanks mansueto. I have tryed all my video edit and convertors nun worked or converted the video.
    This is the 1st time i have had 1 of these files.
    Just trying that program out at moment. Will let you no how i get on.
    Thanks
  5. icutebluezone
    6 Aug 2007
    Thanks mans Program worked good got it done.
    Very nice little program.
    Thanks.
