Hardware Intel Core i5-4670K (Haswell) CPU Review
Discussion in 'Article Discussion' started by Meanmotion, 12 Jun 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Baz
    Baz I work for Corsair
    13 Jan 2005
    In short, got Sandybridge/Ivybridge? You're good.
  3. David
    7 Apr 2009
    Yep.
    Some clock for clock performance and power efficiency improvements, but not a compelling upgrade.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Especially as there is yet another socket change, i just don't get why LGA 1150 has replaced LGA 1155.
    I mean would it have been to much to ask to just have 5 spare pins ?
    Wait for Skylake is what i say, at least then it make buying a new MoBo worth while with DDR4
  5. Kralnor
    Kralnor What's a Dremel?
    9 Jun 2011
    I think you mean Core i5, not Core i7 :)
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Think I'm sticking with my Q6600 and wait for DDR4 to be released and used. I'd better buy an SSD than changing the whole thing (I do not game).
  7. Combatus
    16 Feb 2009
    Thanks - just edited those!
  8. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    Yip, I'm fairly certain I will be buying one of these soon.
  9. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    if i was in the market even with the thermal problems i would not boost it over 4.4Ghz as i dont like to change the voltage much at all anyway...
  10. nathan
    nathan What's a Dremel?
    13 Jul 2012
    first paragraph
    "you're options"
  11. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
  12. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Same. Still haven't found a need to upgrade form my q6600.
  13. Corky42
    30 Oct 2012
    Power draw is very dependent on what version of chip obviously, but i think Haswell draws around the same as previous chips when under load, give or take.
    Where it does save power though is when idle.
  14. Harlequin
    Harlequin Modder
    4 Jun 2004
    2 observations:
    1 when will you update your 6 year old benchmark suite?
    2 - will you stuff it in a case (intel approved build with no case fans) and retest to see just how hot it really gets in the real world.
    thanks ;)
  15. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    jesus i going to get the amd fx6300 . it is half the price. really don't want to get amd since no micro-atx or mini-itx board but hell Intel you going to price your cpu's so high then..
  16. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Worth upgrading from an OC'd i5-750 3.4GHz? I guess I can wait another generation if not, the Geforce 670 keeps me going ok for now, just have to turn Level of Detail down to medium sometimes in games as that's CPU intensive (Tomb Raider for e.g.)
  17. Andersen
    Andersen I'm fine. I'M FINE! *banshee howl*
    25 Nov 2002
    So glad I went for Ivy Bridge.
  18. Elton
    23 Jan 2009
    Turn the details on high. And increase the res. It might help. That said, you can push the 750 much higher than 3.4. I hit 3.6 on the stock cooler rather easily.
    As for this processor. I have Sandy Bridge at 4.3. I have no impetus to upgrade for a few FPS.
    fuus likes this.
  19. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Depending on your usage, you might run into issues. The 6300 is literally half the performance in some areas, part of the reason it's half the price. The minimum Skyrim framerates on the (faster) 8350 aren't exactly compelling next to the old 2500k.
    I agree though, Intel's pricing is getting silly, they're just releasing each new generation at a higher price because they're getting no competition.
    Your best bet might be to pick up SB or IB kit (with mini-ITX maybe) on the forum marketplace.
    fuus likes this.
  20. Guest-16
    Guest-16 Guest
    DDR4 is not likely to become a desktop product as JEDEC has only certified it for ECC server only so far. We're as likely to see GDDR5 for desktops as DDR4 right now.
    fuus likes this.
Tags: Add Tags
