Graphics "Hitching" with Far Cry 1.3 Patch
Discussion in 'Hardware' started by Tim S, 28 Oct 2004.
  1. Tim S
    Tim S OG
    8 Nov 2001
    Is anyone else seeing this?
    I've been using the 66.81 drivers from nZone (WHQL for GeForce 6 series), and I've been experiencing some rather annoying pauses/frame rate drops with the patch.
    It happens with any resolution, and at any setting with/without HDR turned on.
    Basically it can happen when I fire weapons, see explosions, open doors, etc, etc.
    It's not because the frame rate is too low, and it doesn't happen consistently, only in certain places. It appears that it's a driver bug, but I wanted to be sure that it wasn't just me that was having these problems. :blah:
  2. Mister_Tad
    27 Dec 2002
    not getting any of it here with 66.72
    just put on 66.81 this morning though, ill have a quick peep and see if im getting that
    EDIT: yep, and it sucks :grr: , straight back to 66.72 for me, if it aint broke...
  3. Tim S
    Tim S OG
    8 Nov 2001
    Cheers... I'll have a moan at NVIDIA tomorrow and see when they're likely to release a new official "beta" driver :)
  4. bimy
    bimy What's a Dremel?
    5 Oct 2004
    Euh... Dont you guys use 66.77? :worried:
  5. Tim S
    Tim S OG
    8 Nov 2001
    http://www.nzone.com/object/nzone_downloads_winxp_2k_66.81.html
    66.81 are the latest "official" beta drivers, which are WHQL for GeForce 6 series.
    61.77, which I think you are referring to, are a very old driver build. I'm using drivers that are available to the public as I don't believe in using press drivers - you guys cannot get hold of them and therefore can't repeat what I'm recording in my graphics card reviews (in the similar style to the XFX GeForce 6800Ultra review - http://bit-tech.net/review/367)
  6. bimy
    5 Oct 2004
    Ah lol :duh:
    I totally misread the version number... it is 61.77. And by the way, I have a Geforce 6 series Graphics Card so... :D
    Gonna get some new drivres from the site you gave.
