New to the folding team!
Discussion in 'bit-tech Folding Team' started by Petaflops, 14 Nov 2013.
  1. Petaflops
    Petaflops Minimodder
    27 Aug 2013
    Hi everyone.
    Well I finally got my new machine up and running and got folding at home loaded up on it. I've downloaded my first work units and set the slider bar to maximum, and the PC is purring away and heating the study up nicely. I'm running a 4770k with 2 x GTX680's in SLi. Each GTX680 is producing 29k PPD and the 4770k at 100% is doing about 40k. Is that about right? If those in the know can let me know. I keep reading about putting flags on stuff to increase PPD but I have no idea what that means. I'm planning on running my machine 24/7 so I want to try and get the maximum points possible for the electricity used. Any pointers would be appreciated. Cheers.
    Pete
  2. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi use this
    save at the end
    this gives 17 core id
  3. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    is there any flags u can put for the cpu?
  4. johnim40
    johnim40 Minimodder
    23 Apr 2009
  5. Petaflops
    27 Aug 2013
    This doesn't look anything like my folding client! I'm using 7.3.6 and there is no "slots" tab. Am I using the right thing?
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
    im using 7.3.6 its under configure the cog
    so rightclick the icon by clock
    click on advanced controle
    then on configure
    then slots
    double click on gpu
    then click add
    in name box type client-type
    in value box type beta
    click ok
    click ok
    click save
    the when the other 15 core is finished it will download a new 17 core
  7. steveneedle
    2 Jan 2010
    I can c that is for the gpu flags....is there any you can use for cpu?
  8. johnim40
    johnim40 Minimodder
    23 Apr 2009
    -bigadv --client-type=bigadv
    -smp <number> --smp --cpus <number>
    i dont do cpu folding only gpu but someone will jump in and help soon
  9. steveneedle
    2 Jan 2010
    I haven't got a clue where you put those.....
    can u put those flags in a gpu at any time?
  10. johnim40
    johnim40 Minimodder
    23 Apr 2009
    post 8 is cpu stuff and yes any time but they wont come into effect untill the current core is finished and the new 1 is downloaded and started
  11. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    There are flags for CPU Folding as mentioned by johnim40 - 'smp' is on by default in v7.3.6, and 'bigadv' and 'bigbeta' are for monster CPU's only (I think more than 24 threads - certainly it is for the latter flag).
    You could add 'advanced' to get newer code which comes out of beta testing, but that sometimes comes at a cost of baby-sitting because of bugs/stability.
  12. Petaflops
    27 Aug 2013
    I think that my starting screen if different to yours. I have just 5 tabs 1. Home 2. Identity. 3. News 4. Help 5. About. None of them have a configure button and none have a clock. I'm a bit stumped. I think I might be using some basic GUI interface for beginners rather than your more advanced one. Any tips?
  13. johnim40
    johnim40 Minimodder
    23 Apr 2009
    the clock is the windows desktop clock
    i will look tomorrow afternoon for you
  14. Petaflops
    27 Aug 2013
    My GTX680's are down to 21K PPD and my 4770K is doing 26K PPD so I suspect that something is wrong, if a GTX760 is giving 65 - 75K PPD. Is it my drivers or this Beta flag that is the issue?
  15. Petaflops
    27 Aug 2013
    Are there different interfaces for the Folding @ Home client? I'm still trying to suss out about these flags to get my PPD up, but I haven't made any headway there. My client is on the following web page.
    http://folding.stanford.edu/client/
    Is that correct or is there a more advanced client interface that I can use? Any help much appreciated.
    Pete.
  16. DocJonz
    24 Apr 2009
    v7.3.6 is the latest. There is a configuration option for 'Advanced' and 'Expert' mode in the GUI.
    For your PPD, they just announced roll-out of Core 17 to full F@H (not just beta and adv), but in case that hasn't come in to effect yet, use the beta flag for the GPU.
  17. Petaflops
    27 Aug 2013
    Hi Doc.
    There is no advanced or expert tab or button on my GUI. It's just really basic, and I can't configure anything. I can't even turn the folding off from inside the GUI. There are just the 5 tabs as I said in post #12 but nothing else. On the up side I have worked out how to roll back the Nvidia drivers back to an earlier version. I can see now why it's difficult to persuade people to start folding as it seems to require a lot of technical knowledge.
    Thanks.
    Pete
  18. Petaflops
    27 Aug 2013
    As a quick after thought, would it be worth me posting a screenshot of my basic client so you can see what I'm talking about. If so, how do I go about doing that? Cheers.
    Pete
  19. johnim40
    johnim40 Minimodder
    23 Apr 2009
    hi im using win7 what are you using?
    i use snipping tool in win7 in accessories
    goto http://folding.stanford.edu/ download tool and install
    setup you details eg id and team
    open FAHControl from windows startbar
    double click on gpu
  20. Petaflops
    27 Aug 2013
    Hi John.
    My new computer is windows 8, recently upgraded to 8.1. That's half my problem as it takes an age working out how to do anything on the damn machine. Also the root of my problem it seems is the starting program that I have installed. Mine is nothing like yours. I was going to send you a screenshot but I am not allowed to send attachments so I can't. How do I get the F@Hcontrol program and not just this very basic client. If you post me an email address then I can send you the screenshot of what I have got installed. I followed you link and downloaded the software again, but it is just the same thing installed again. Help.
    Pete
