Setting Up FaHMon under Linux
Discussion in 'bit-tech Folding Team' started by cgcox1, 25 Apr 2009.
  1. cgcox1
    cgcox1 Obessed Folder! Me? Surely not!
    24 Apr 2009
    Hi all,
    I know i have asked this before (and had the answer), but as the cpc forums now seem inaccessable could someone please run me through how to setup FaHMon 2.3.99.1 on Xubuntu 9.04
    Doc, anyone?
    Cheers.
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Yep, that seems to be a big downside of closing off the other Forum - you can't direct people to key threads ....
    I have tried to get FahMon 2.3.99 going on Ubunbtu (8.04), but wasn't having much success - Unc fungus is your man, and he's around on this new forum .....
  3. uncle_fungus
    uncle_fungus P/T Folding@home developer
    27 Mar 2009
    This assumes you've already extracted the source archive, an you know where you extracted it to ;)
    1. Make sure you have all the necessary software to compile and run FahMon
      Code:
      sudo apt-get install g++ libwxgtk2.8-dev libcurl3 libcurl4-openssl-dev
    2. Change into the FahMon source package directory
    3. Configure the sources for installation and compilation
      Code:
      ./configure
    4. Compile the sources. If you want to speed up compilation, add -j $CPU to the end of the next command, where $CPU is your CPU count + 1. (i.e. on a dual core machine use -j 3)
      Code:
      make
    5. Install FahMon
      Code:
      sudo make install
    Incidentally there is a detailed guide for how to do this included with the FahMon sources. Look in doc/help/User_Guide.pdf
    Page 5 details the installation process for Linux.
  4. cgcox1
    24 Apr 2009
    Thanks
    Thanks for that Uncle_Fungus.
    I have got it running fine on one VM machine :D, but in another when i double-click the FaHMon icon nothing happens. There is a short pause were the cursor disappears (as if it is trying to execute the program) and then the cursor comes back.
    The getting and install command has worked fine as when i run it again it does need to download any packages and says they are all up-to-date. And the ./configure, make, and sudo make install commands also seem to have run through fine.
    Any clues as to what could be happening, i really do not have the foggyest when it comes to Linux.
  5. uncle_fungus
    27 Mar 2009
    Open a terminal again, and run
    Code:
    sudo ldconfig
    For some reason the installer doesn't run this correctly on certain machines. It updates the library cache so that FahMon can find libwxcurl (installed as part of FahMon).
  6. cgcox1
    24 Apr 2009
    Double Cheers
    Thats done the trick mate. Cheers very much. :thumb:
  7. DocJonz
    24 Apr 2009
    I guess that might be my problem - I'll check when back in Blighty ;)
  8. cgcox1
    24 Apr 2009
    Uncle_Fungus is just excellent isn't he!
