News University of Bristol opens up its quantum processor
Discussion in 'Article Discussion' started by Gareth Halfacree, 6 Sep 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    My brain hurts after reading that, I think I'll go for a lie down.
  3. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Maybe something for the NSA to give a try...
  4. Fused
    Fused Minimodder
    19 Jun 2007
    "I think I can safely say that nobody understands quantum mechanics." -Richard Feynman,
  5. theshadow2001
    3 May 2012
    But can it run Crysis?
  6. Panos
    Panos Minimodder
    18 Oct 2006
    But can it play Total War Rome 2 on Extreme settings?????
    (the new "Crysis")
  7. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Not only can it run it, it could predict the out come of the game based on the first move of the units. Theoretically.
  8. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    I still want to know how someone would program a quantum computer. Logically, they don't make sense, at least with the info I've heard about them so far.
  9. theshadow2001
    3 May 2012
    It can both run it and not run it at the same time
  10. Kruelnesws
    Kruelnesws What's a Dremel?
    7 Jan 2012
    It can play Crysis, it can't play Crysis or it can do both at the same time...
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    I wonder if it`ll be any good at bit coin mining....
  12. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    You have mined 100 bit coins..... you have a 100 bit coin bill to pay. :p
  13. Andy Mc
    Andy Mc Modder
    23 May 2002
    That was my first thought. Also the same goes for whatever the NSA is using to break crypto.
  14. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    it can run crisis- maybe
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    What a birthday present.
  16. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    so, you can give a quantum computer a question, and it will pretty much be able to instantly give you every possible outcome, but what then decides what the best/correct outcome is?
  17. hyperion
    hyperion Minimodder
    30 Jun 2007
    Hah, quantum jokes! I don't get it...
  18. Gradius
    Gradius IT Consultant
    3 Feb 2009
    I don't think it will be ever possible.
  19. themassau
    themassau What's a Dremel?
    23 Mar 2012
    it is a probability system. a good example is whit breaking a code it trying 1M codes in one try an while it is calculating it can be code 1 ,2 3 etc but the system must be designed in such a way that the right answer has the highest probability to happen. so if code 10598 is the right answers than it has to have a bigger chance than all other answerers.
    the system collapses at the end of evry calculation so it only gives one answer at the end not 1 maybe 0 but just a plain 1 or 0.
    now repeat the calculations 1000 times and viola the answer is the code you got the most.
  20. Alecto
    Alecto Minimodder
    20 Apr 2012
    I'm not very smart so this might sound naive: if ordinary (silicon-based) computer takes twice as long as quantum computer to perform a task which provides both answers to a problem with two answers, why not emulate quantum computer in twice (or whichever factor is appropriate) as much hardware ? Why the hassle with liquid nitrogen and the rest of that fancy machinery for something which sounds as trivial as emulating Intel's 4004 on a 80386SX ?
