Linux Which is the best Linux distro
Discussion in 'Software' started by meandmymouth, 7 Jan 2011.
  1. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I use Ubuntu 10.04 on my PC and I'm pretty happy with it
    I was wondering whether any other distros are better.
    I've look at Fedora (which is what one of my uni tutors uses) and mint
    Are either of these any better or have any advantages over Ubuntu?
  2. Coltch
    Coltch Minimodder
    3 Jul 2009
    Put simply there is no best Linux distro - they all have pluses and minuses.
    I use Fedora 14 on my Laptop and am quite happy with it.
    The best distro I've used is probably Debian Lenny - not as upto date as Ubuntu releases, but rock solid - may try Debian Squeeze soon.
    Personally I could never get on with Ubuntu - don't know why as I'd been using Debian most of the time.
  3. minimad127
    minimad127 CPC Refugee
    24 Apr 2009
    couldnt put it better myself, however the big bonus is because they are free you can try them till your hearts content
    i am personally using Lubuntu on a old ultraportable laptop (dell x300) and find it great, boots up so quickly and everything that i want to run on it is super quick, but it has its downfall such as no software centre but its fine for me at the moment,
    will probably have a look at Mint LXDE when it is released, also been thinking about trying peppermint - but then again with only a single 1.2 ghz cpu and 512 ram i have to look at the low resource distros for my lappy
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    i use crunchbang lite, nice minimal and fast without a load of programs i have no use of installed by default. plus it gets on well with my old athlon xp system i use for my linux station.
  5. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    No right answer to this one, it's a matter of taste. Gentoo and Arch are my favourites.
    http://distrowatch.com/
  6. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    I'm a big fan on LMDE for desktop use. As flashy as Ubuntu but with a solid Debian base. (Like Ubuntu used to!)
    I also use and recommend Crunchbang (my netbook), Tiny Core (an old P4 desktop) and Debian (server).
  7. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    I've been using LM10 across the board for the past year, but I'll likely be going to crunchbang, arch, or slackware when I get my new one this summer.
  8. GeorgeStorm
    16 Dec 2008
    I use Fedora on my laptop
    May try debian server for my NAS (currenly running FreeNAS)
  9. emilyjohnson
    emilyjohnson What's a Dremel?
    12 Apr 2011
    Re: Linux Which is the best Linux distro.
    I use Ubuntu 10.10 on my PC & workstation and I'm pretty happy with it.
  10. Glider
    Glider /dev/null
    2 Aug 2005
    Which is the best Linux distro... The one that suits you...
    Gentoo for me, Ubuntu annoys the crap out of me with its bad choices and forced way of doing stuff...
  11. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    Just get virtual box from sun and go ISO mad and try them all! I have a unbuntu machine which i run my minecraft server on but i like centOS quite alot as well. Just personal choice tbh.
