Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 21st Feb 2017, 18:46   #1481
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
Cheers for the advice on juice suppliers.
Originally Posted by Shirty View Post
I can't believe that on a forum dedicated to tinkering and hand crafting you are all still buying e-liquid.
DIY is soooo easy, it's only a couple of quid for 100ml + and you can make whatever recipe you fancy, at whatever strength and PG/VG ratio you like.
My dear Shirty, you have no idea how incredibly, exquisitely lazy I am
Back before I packed in vaping last year I did mix my own. I usually used pre-mixed flavour concentrates (Red Astaire FTW), wasn't very adventurous TBH. Now that I've started vaping again I really do need to get back into mixing, TPD is gonna kick my arse soon enough.
I blame the TFV8 personally...
I have the TFV8 Baby and yeah, it's a guzzler alright!
Originally Posted by Vault-Tec View Post
It could actually be the nicotine. I'm still on 18. Going to drop to 12 soon.
Good god man! 3mg is enough, I can't even imagine going over 6mg!
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 23rd Feb 2017, 14:04   #1482
Sentinel-R1
Morse Monkey
Sentinel-R1's Avatar
Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.Sentinel-R1 is definitely a rep cheat.
No wonder you're feeling sick V-T, if you're on 18mg juice with a modern dual coil atomiser. Are you sure that avatar pic isn't actually your mugshot and you've gone green and orange from nic poisoning??
18mg is fine on old school style 1.8ohm single coil heads if you've just come off the fags... but if you're sub-ohming, you really don't want to be above 6mg as the nicotine delivery is much more effective.
__________________
6700K @ 4.7GHz | EVGA Z170 FTW | Asus ROG Strix 1080Ti OC | 16GB Corsair DDR4-3000 | 500GB 960 EVO NVMe | 2x 500GB 850 EVO SSD
Corsair Carbide Air 540 | NZXT Kraken X62 | 3x Corsair HD120 RGB | 3x Corsair ML140 Red | Asus ROG Swift PG279Q 165Hz
Sentinel-R1 is offline   Reply With Quote
Old 25th Feb 2017, 00:24   #1483
GTIgeneral
Supermodder
GTIgeneral's Avatar
GTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming SaiyanGTIgeneral is a Super Spamming Saiyan
Just ordered myself the Smok Stick V8 in rainbow colours, anyone got this mod? going to be a bit strange going back to a standard tank and coil after using a limitless RDTA for so long
GTIgeneral is offline   Reply With Quote
Old 11th Mar 2017, 15:19   #1484
tk421
Idiot.
tk421's Avatar
tk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for presidenttk421 should be considered for president
wow ... this thread is still going ... kinda.
after 4.75 years of vaping, i have finally found an all-day ... no more carrying 4 devices and a prius worth of spare batteries ...
picked up a griffin 25 (no top air) and it has become my go-to tank. .5Ω-ish fused clapton single coil, at around 42w on a IPV 400 gets me by.
the all day juice is a clone of mountain oak's white lotus ... apricot, nectarine, papaya, marshmallo, vanilla swirl.
i still have a menthol-y tobaccoish juice i make, in my evic vt / cubis pro setup. i only vape that in the mornings and when i'm sinusy (yay allergies!)...
__________________
:gamebox: |r7 1700x|asus b350m-a|2x8 corsair white LED 2666|256 960evo|256 810|2+4tb WD blues|h100iv2(soon!)|4xhd120/LNP/CLmini|carbide Air240-white|dell s2340m|
:htpc: q6600@3.03|MSI Neo3f(p43)|4x2gb pc6400|evga gt 710|CM590||vizio D50u-D1 |
tk421 is offline   Reply With Quote
Old 17th Mar 2017, 19:26   #1485
atanum141
I fapped to your post!
atanum141's Avatar
atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!atanum141 - it's over 9000!!!!!!!!1!1!1!!!
I think I have a problem
Serpent Mini 22mm Silver
Serpent Mini 25mm Black
Sapor RTA 24mm Black
Serpent RDTA 22mm Silver
The Troll RTA 24mm Silver
In need of more mods...........
__________________
Welcome to Thunderdome, B*tch
XBL: atanum141
atanum141 is offline   Reply With Quote
Old 17th Mar 2017, 21:59   #1486
tk421
Idiot.
tk421's Avatar
i really like my original Troll and freakshow mini. never really messed with any of WoToFo's other stuff.
and what is with the boxes now? both that i had came in little round aluminiuminum tins.
__________________
Old 17th Mar 2017, 22:02   #1487
Vault-Tec
Banned
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Well I dropped to a 2 ohm single coil, no change in skin condition. There wouldn't be, it's eczema apparently. Went to a dermatologist the other day and apparently it's not my cigarette just my age. Great lol.
Definitely prefer this old Aerotank though. It holds about twice as much and lasts longer.
Vault-Tec is offline   Reply With Quote
Old 25th Mar 2017, 03:23   #1488
Evolutionsic
Gives credit where its due
Evolutionsic's Avatar
Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.
Slowly getting back into vaping , after my cuboid broke after no time at all i kinda gave up and went back to normal cigs however! Roll on today where i’ve got my TFV8 and a new purchased Kbox 160 i’m back at it again!
Still have all my supplies for making e-liquid too, which is probably about 3 years worth! Made a friend like 600mls of “heisenberg” (cough syrup more like xD)
__________________
Loose lips sink ships
Evolutionsic is offline   Reply With Quote
Old 27th Mar 2017, 09:08   #1489
Sentinel-R1
Morse Monkey
I've had the carbon freakshow for years now. Love it. Just wish they'd do a 25mm version with a better post and deck design.
__________________
Old 27th Mar 2017, 10:52   #1490
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Finally got some mixing supplies through:
Need to get some more nicotine ready for May though.
__________________
Old 27th Mar 2017, 10:56   #1491
Sentinel-R1
Morse Monkey
I used to use Lucemill but it seems they've stopped selling Nic, in anticipation of May's law change. DarkStar seems to be the best value at the moment, now Lucemill have withdrawn it from sale.
__________________
Old 27th Mar 2017, 11:08   #1492
Grimloon
Hypermodder
Grimloon's Avatar
Grimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpitGrimloon is almost as Godly as yodasarmpit
Definitely DarkStar for nic, best prices and their VG nic base just doesn't seem to denature as fast as most other stuff I've used. I need to get a couple of litres in on "just in case" grounds
PG and VG I get from Amazon, Classikool stuff. Proper VG too, none of this aqueous muck
For US style concentrates I can't fault Cloud House, they keep expanding the range as well so there's always something new to try. They also have a habit of chucking a couple of concentrate tasters in with every order I make so I always get to try flavours I might not necessarily order.
Grimloon is offline   Reply With Quote
Old 31st Mar 2017, 15:16   #1493
Vault-Tec
Banned
Guys, just thought I would let you know.. Vapourlites are having a clearout sale. Their juices for a 10mm used to be 3.99 or three for a tenner. They would then give you about 15-18% off (it used to be 20-22 so I stopped ordering from there) and their liquid has the best flavours I've had yet, from anywhere.
Any way, they are doing a sale ATM where you can get certain flavours and strengths for 99p. You can see what's in the mega sale here.
http://www.vapourlites.com/electroni...hot-deals.html
OK, when you checkout add the code VL4040 for an extra 40% off. So basically they are selling 10ml bottles for 60p each, down from 3 for a tenner.
The Grape and Passionfruit (if you like your fruit flavours) are amazing. There's a few bits of hardware in the same sale too, though I didn't really need anything.
HTH !
V-T
Old 31st Mar 2017, 15:27   #1494
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Much obliged, I'll check that out later.
__________________
Old 31st Mar 2017, 15:42   #1495
Vault-Tec
Banned
Sweet. Just bear in mind it ends at midnight.
Old 31st Mar 2017, 17:30   #1496
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
50% off at Vampire Vape
https://www.vampirevape.co.uk/
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is offline   Reply With Quote
Old 31st Mar 2017, 19:40   #1497
Evolutionsic
Thanks also you can use the 10% discount coupon on first orders = VV10
I just ordered
  • HOME RUN - 30ML AMERICAN DESIRE RANGE
  • PINKMAN - 60PG/40VG E-LIQUID (30ML)
  • BLACK JACK - 60PG/40VG E-LIQUID (30ML)
  • ATTRACTION - 60PG/40VG E-LIQUID (30ML)
whats everyone's absolute favourite flavour?
__________________
Old 31st Mar 2017, 20:39   #1498
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
OK so whoever supplies MakeMyVape have utterly vile flavour concentrates. Tried their "Heisenberg type" and it was totally foul - some really odd flowery-ness, an attempt at menthol that was more like mint, and some weird greasy sharp-tasting thing that I just can't put my finger on. 100ml of juice wasted. Their "Sweet strawberry" isn't up to much either; it's not quite strawberry, I can definitely taste the lies.
Back to Red Astaire and proper Heisenberg concentrates it is.
From Vampire Vape? Heisenberg. Of all time? Probably Red Astaire (T-Juice), with Snake Oil (TMax) coming a close second.
__________________
Old 31st Mar 2017, 20:57   #1499
mrlongbeard
Ultramodder
mrlongbeard's Avatar
mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.mrlongbeard is definitely a rep cheat.
Liquid EFX's Fried Cream Cakes.
mrlongbeard is offline   Reply With Quote
Reply
Tags
say yes to skimmed milk
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
