Reply
Thread Tools View Mode
Old 10th Nov 2015, 11:08   #21
sagar
Minimodder
sagar has yet to learn the way of the Dremel
Update 10
The composite material is here, it is a composite of PVC sandwiched between aluminum.
The color of the sheet is golden which i would be painting
Also just wanted to say that i wont be able to update or work on the mod for the next 5 days due to a festival.
Till then Peace
sagar is offline   Reply With Quote
Old 11th Nov 2015, 15:54   #22
sagar
Minimodder
What do you guys think
Air cooling or Water cooling ?
Would be able to fit 2x360 rads but if I do water I'll do only one, and if I do air cooling I'll have to use an ITX cooler that is a low profile one.
Would go this way if I get enough cash
Old 21st Nov 2015, 09:55   #23
sagar
Minimodder
Update 11
Finally back on the project.
Sorry for the delay was caught up on some work
Here it is, the cutting of the side panels and the support structures
The full size
Cut into an approximate shape using a grinder
The support triangles cut
Just a hell lot of dust and dirt all around me as well as on me
Will finish these in the next couple of days.
Had in mind that i would complete this project by December but due to a change in the college exam schedule wont we able to progress at a speed that i wanted
Old 30th Nov 2015, 04:26   #24
sagar
Minimodder
Crap, today I noticed bends in my aluminum angles which were going to act as support for the whole case.
Need go find another way out.
Next update will be after mid December.
Till then peace
Old 7th Jun 2016, 10:47   #25
sagar
Minimodder
Update 12
So guys,
I'm back again at the case.
had a long break but now I'll try to complete this in a week or so.
The break caused me to change the whole case look. (Thanks to some of the modders)
Cut and filed the side legs of the case.
From now on will be eye-balling everything rather than depending on a 3D sketch.
More pics to come soon
Old 8th Jun 2016, 19:49   #26
sagar
Minimodder
Update 13
Today got a wooden frame/jig made up so i could get the sides perfectly squared for the case
Frame with the metal angles
Test fitting an old m-atx mobo
Testing the power supply and HDD tray mounting positions
Got the HDD tray from the old case as well
Had these extra side panels from the old case which i cut up. Would use these as the double-mid plate for the case
Till tomorrow then, PEACE
Old 9th Jun 2016, 16:38   #27
sagar
Minimodder
Update 14
Got the aluminum angled rods cut to fit each other
A preview on the case
The support pieces for the frame
Checking the fit of the support
Old 10th Jun 2016, 06:48   #28
PH0ENIX
What's a Dremel?
PH0ENIX has yet to learn the way of the Dremel
where you from?delhi??
nice mod but the case design looks little plain.try pimping it up
PH0ENIX is offline   Reply With Quote
Old 10th Jun 2016, 12:33   #29
sagar
Minimodder
Update 15
Mocking up the side panel on a piece of paper.
PS the giant cutout in the middle is for GLASS or ACRYLIC.
Cut the paper and transferred the design on the PVC/aluminum sheet I have
I'm from Gujarat, and yes the case might look plain right now but all the panels I'm adding will make it pop
Old 13th Jun 2016, 17:06   #30
sagar
Minimodder
Update 16
Didn't get much done in the last 3 days, was waiting to get my hands on a cutter.
Finally borrowed it and roughly cut out the outlines for the side panel.
Tomorrow is gonna be a tiresome day as will have to cut and smooth out the edges.
Till then, PEACE
Old 14th Jun 2016, 16:38   #31
sagar
Minimodder
Update 17
Got the side panels trimmed today.
Will be sanding them tomorrow as my old sandpaper isn't effective anymore.
This is how it will look assembled
Till then, PEACE
Old 16th Jun 2016, 15:16   #32
sagar
Minimodder
Update 18
It took me 2 days to get the side panels nice, flat and almost smooth.
Took a lot of filing and sanding along with elbow grease.
Here id what it will look like on the case
Till then, PEACE
Old 18th Jun 2016, 19:29   #33
sagar
Minimodder
Update 19
Used tape to stick all the angles to the side panels, which were also held together by tape
Also got my hands on a drill today.
Drilled out all the holes and screwed them
This wood is going to act as a base for the case. Drilled out holes for the hinges that would be connected to the sides.
This is how the case rests right now with the sides attached.
Will be changing the way they sit tomorrow.
Till then, PEACE
Old 21st Jun 2016, 18:13   #34
sagar
Minimodder
Update 20
Took me a few days to design and build the top covering of the case.
Finally came up with this design. Cut the panels in the shape and mocked it up.
Drilled holes in the frame to mount these panels.
The idea earlier was to leave no space between the flaps.
Later changed the idea and put a few spacers between the panels to give it an elevated view which makes it look cool but also increases thre air flow of the case
The project is almost 70% complete.
Till then, PEACE
Old 26th Jun 2016, 09:45   #35
sagar
Minimodder
Update 21
Had to take some time to figure out the stand/legs for the case
Found my old aluminum angles which were cut, marked some lines and started cutting
Left unfinished | Right finished
Got all the legs cut and finished
Marked the lines where the feet were to be located
Stuck the legs using tape just for mock up
With the scavenged panels from my disassembled case, which is going to act as the main base of the case
Test fit the mobo and psu into the case earlier but still needed an extra few mm of space for perfect fit so added 2 pieces of wood to rise the top
Next steps are gonna be attaching the feet to the case using screws, painting, getting the mid panels cut and then finally mounting the hardware inside.
Till then, PEACE
Old 8th Dec 2016, 19:13   #36
sagar
Minimodder
Update 22
So guys back at it again.
Finally got time to work on the case again.
Made some major changes on the case and hardware.
Got a cooler master hyper 103 instead if a low profile cooler so had to modify the case for it.
Decided to remove the PSU from the case and mount it to the bottom.
Decreased the width if the case and cut new bottom panel for it.
Traced the cutout fot the IO
Working on the top panel yet again using the screwdriver as a chisel
This is how i think im gonna mount the base of the case and the frame.
Making the mounts and supports for the base joint
The next update will mostly cover the base.
Till then, Peace
Old 9th Dec 2016, 17:56   #37
sagar
Minimodder
Update 23
Today's work had no major progress because most of it went in vain.
Worked on making the back panel for the case
Also worked on the support connecting the base and case because the last one was a few degrees off and hence lead to blockage of the IO access panel
Here the new support structures added.
Had to work on the top panel again as I forgot to take in consideration the bend in the frame and now have to cut them down to fit inside the frame rather than outside it.
Till then, Peace
Old 12th Dec 2016, 17:50   #38
sagar
Minimodder
Update 24
Had been working since Friday.
Got a lot of work done
First a previous case progress pic.
Started working with the back panel of the case. Straightened it out and fixed everything to length.
Next started with filling the holes that are of no use now that the design has changed. Used m-seal to cover them up.
Next sanded them up and got their surface prepped.
Next worked on removing excess material from the front area of the case to house the front panel.
Next started working on the front panel. Had to remove a lot of material from the center and then had to break it in such a way that the panel didn't break. But before i broke it I sanded the surface for the paint for later on.
Bent it and made a jig for the same.
The next step was to fill it with m-seal so that it can be supported and i could get that line in the middle like it was one piece. After applying m-seal had to let it dry fro about 2-3 hours. Then I started sanding. Took me about 1.5 hours to get it sanded for the perfect line in the middle. (*sorry for the bad picture)
Next had to cut support structure to support or mount the front panel and also to fill the gap between the top and front panels. This will also act as a housing for the power and reset switches.
Attached everything to the case using tape as don't have a drill at the time.
Now most of the case is done. The only things remaining are
1) mid panel for the mobo and hard drives
2) Working on the base
3) Paint
That's it, a few more days and it would be done.
Till then, Peace
Old 22nd Dec 2016, 07:46   #39
sagar
Minimodder
Update 25
I had been waiting on the drill for the last few days. Finally got it.
First thing i did was drill and screw the top to mount the top air vents.
Next drilled and screwed in the back for the back panel.
Then I stared on drilling the holes for mounting the bottom support brackets and the base.
Later mixed some epoxy putty to mount the front of the case to the front support frame.
Added some tape to help remove the epoxy.
Also scratched the surface of the front panel to help in better adhesion, but unfortunately it didn't hold up.
Here it is mounted to the base and standing tall.
Till then, Peace
Old 23rd Dec 2016, 17:57   #40
sagar
Minimodder
Update 26
Got a few bits and bobs done today.
Mixed up some epoxy and filled the gap between the top and the front panel connector and sanded it. This is the same short bot of panel which will hold the power button.
Test of the whole assembled case. Had more pics but the shitty cam in my new phone messed it up.
setup 1 with the slanted base.
Setup 2 with the base flat. (my mom insists that I go with this setup)
What does the community think of the setups, which would be better.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
