Old 29th Dec 2015, 13:05   #1
Scorpuk
Hypermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
0 ppd :(
Hey Doc did you have to manually change your ProjectInfo.tab file to get the beta work units to show PPD?
I switched to json and its finally downloading the file, but none of the work units I am working on are in it, but you did have one of them; P11403. (With the html link the file was not downloaded)
Units I am working on at the moment:
  • P11700
  • P11401
  • P9172
  • P9018
  • P9017
  • P7528
Cheers.
__________________
Enthoo Evolv ATX Glass; Asus Maximus VIII Formula; i7-6700K; GTX 1080 Ti SLI; 32GB DDR4 3200MHz; SuperFlower Platinum 1200W; Samsung 950 Pro 512GB M.2 ; 4TB HDD; Windows 10 Pro.
Scorpuk is offline   Reply With Quote
Old 29th Dec 2015, 15:38   #2
DocJonz
Another CPC refugee .....
DocJonz's Avatar
DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.DocJonz is the Cheesecake. Relix smiles down upon them.
Hi there - Are you referring to displaying the PPD in HFM.NET? There is a work around until Stanford/Harlem get things in order, and that is to change the 'Project Download URL' in the 'Preferences - Web Settings' tab to: http://87.98.172.206/psummary_manu.htm
__________________
Folding stats
Folding Farm Stats (HFM): http://www.docjonz.net/summary.html
DocJonz is offline   Reply With Quote
Old 29th Dec 2015, 15:43   #3
Scorpuk
Hypermodder
Cheers Doc.
Sorry did forget to mention it was HFM.NET.
That's it sorted now.
__________________
Old 17th Feb 2016, 21:58   #4
DocJonz
DocJonz's Avatar
Scorpuk - Just in case you missed the update to the HFM sticky thread, there's a patched release of HFM.NET which sorts out the project summary location;
Bit-tech Folding HFM.NET Sticky see post #79.
__________________
Folding stats
Old 18th Feb 2016, 07:03   #5
Scorpuk
Hypermodder
Cheers Doc.
lol replied to wrong thread. too.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
