Old 23rd May 2016, 13:03   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
GTX Titan- existing backplate
Just picked up a second hand EVGA GTX Titan X and wonder if the existing backplate will work with a EKWB block as I don't really want to purchase another backplate if I don't have to
hairyknacker is offline   Reply With Quote
Old 24th May 2016, 13:29   #2
Akira749
Multimodder
Akira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the DremelAkira749 has yet to learn the way of the Dremel
You can probably re-use the backplate but you will need to provide your own longer M3 screws. 6mm or 8mm ones should be fine since the standard EK ones are 4mm.
Akira749 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
