Reply
Thread Tools View Mode
Old 6th Sep 2016, 23:23   #21
Deblow
Supermodder
Deblow's Avatar
Deblow has yet to learn the way of the Dremel
Back-plate for the sound card in place, used some velcro to hold it down as I will be needing to mess with it later in the build, its also a bit more tidy than using the screws on the card to hold it.
got this cutter some years back for my model making, helps add some detail to the plastic, also very useful for cutting the plexi
Bit wonky as it's not fastened in place just yet..
Same again for the back cover.
Ordered some more white plexi, so most the parts will be re-cut using the old ones as a template.
After some testing I decided to have the RAD facing the standard way rather than upside down.
Just didn't have the room I wanted at the top for all the pipe and fittings.
Deblow is offline   Reply With Quote
Old 9th Sep 2016, 18:51   #22
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking good.
Using a scratch and crack cutter? Man! You must have a masochistic side to you.
__________________
The Iron TurnipBlooBallsHypnotoadPlankReservoir-ThingsNUC-TooobularC7WaterblocksCrusty McBeanbags IIIGlassGreen
Powered by: AMD∑Gigabyte∑Swiftech∑Hardware Labs∑Noctua∑DangerDen
Cheapskate is offline   Reply With Quote
Old 9th Sep 2016, 21:21   #23
Deblow
Supermodder
Deblow's Avatar
Originally Posted by mad_mic3 View Post
coming along nicely
Originally Posted by Cheapskate View Post
Looking good.
Thanks guys,
Well its fun living on the edge, holding your breath as you start to snap the expensive plexi while
quietly praying it wont decide to change direction
Cutting clear seams to be a lot more easy than the white, must be something to do with the color pigments.
Old 9th Sep 2016, 21:34   #24
Deblow
Supermodder
Deblow's Avatar
This has been the best part of the build so far, the results from the extensive paint coats, sanding, buffing and polishing have paid off, by far the best paint finish I've achieved with gloss.
This has taken weeks, not a easy task especially with the sharp edged all over the panels making it very easy to take the paint of all the way down to the primer if not do perfect.
This is the result after the gloss had been put down.
Plenty of orange peal and although it looks shiny I cant stand the peal.
So after the couple of weeks painting then sanding I got the gloss down and had to wait a week or so for the gloss to harden, then I carefully sanded down the gloss to get the surface as smooth as possible with paper.
my hands looked like I had been sat in the bath for 2 hours lol
Because I'm so happy with the result I will show you all a good handful of photos.
Hope you like the result as much as myself and the next update will be installing some of the EL bits.
Old 9th Sep 2016, 23:47   #25
Deblow
Supermodder
Deblow's Avatar
Another sweet example of your painting skills
arh the good old days of bleeding finger tips from rubbing down, I dont miss them
Thanks Mic, going to be testing some more painting skilz later and if all goes to plan I will post some
pics, if not I will delete this post and never mention it again lol.
Old 10th Sep 2016, 18:25   #26
Deblow
Supermodder
Deblow's Avatar
Sound Card almost complete, just need to add something to the top plate.
Old 11th Sep 2016, 01:51   #27
Quantum-192
Modder
Quantum-192 has yet to learn the way of the Dremel
Amazing paint work and worth all of your effort
__________________
Project Evie Steampunk Build
Quantum-192 is offline   Reply With Quote
Old 11th Sep 2016, 14:00   #28
Deblow
Supermodder
Deblow's Avatar
Thank you, I'm glad I put some effort in to the paint.
Would have regretted it later lol
Old 11th Sep 2016, 15:55   #29
Deblow
Supermodder
Deblow's Avatar
Started carefully placing the EL wire and some tapes, this was tricky, glued my fingers to the wire a couple of times lol
Put down some tape on the none flat parts for some protections and as a guideline.
Top is done, sides and front still need some more work doing.
Hopefully you now have a better idea of the final look im going for with the build
Old 14th Sep 2016, 10:18   #30
Bogdanovki
What's a Dremel?
Bogdanovki has yet to learn the way of the Dremel
Nice job Overlord. Im grateful for a Colour Blind Mod Project. Its going to help a lot of people. What will happen to the fan-made one though?
Bogdanovki is offline   Reply With Quote
Old 15th Sep 2016, 02:53   #31
Deblow
Supermodder
Deblow's Avatar
Thanks, colors are in trend with the Tron theme.
like most builds I also think it looks better when you stick to 3 colors or less.
I don't know what "fan-made" is in reference to?
Old 15th Sep 2016, 14:50   #32
Quantum-192
Modder
Impressive! You have the Tron look spot on
__________________
Old 25th Sep 2016, 00:57   #33
Deblow
Supermodder
Deblow's Avatar
Thank you, bit slow on progress atm as im awaiting some more parts, also started a white version of this with the MasterCase 3 Pro, best of both worlds when complete
Old 30th Sep 2016, 21:21   #34
Deblow
Supermodder
Deblow's Avatar
As im awaiting some more parts for the main Tron build I've been working on a couple of things
and due to the time needed for the paint to dry im moving between the main build, Tron (black) and
my second mod, Tron 2.0 (white).
I wont be doing a full build log for the 2nd Tron case mod but I will add a couple of photos to this log.
As I mentioned before, not to happy with the original PSU cover I did with clear plexi so I ordered some more
white and did the cover again, much better now for the reflections im wanting to capture.
Like with the sound card, added some EL lightning to the RAD.
Sticking with the EL, time to get the Tron disc painted to better match the case and the original look of the disc.
I really enjoyed this part and im very happy with the result.
After some very careful and painfully slow masking the disc is almost completed, painted with water-based black so as not to damage the plastic coating.
here's some pics of the Tron 2.0 mod, all the paintwork is completed and im now working in the lighting.
Old 30th Sep 2016, 22:17   #35
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
If I painted things to look like that I would have to put them in a mosquito tent to stop the dust getting on
Looking great man.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 2nd Oct 2016, 19:31   #36
Deblow
Supermodder
Deblow's Avatar
Looking great man.
lol thanks, plan was to have it soooooo smooth that the dust just falls off
Old 3rd Oct 2016, 01:01   #37
Bartacus
Supermodder
Bartacus's Avatar
Bartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming Saiyan
Bartacus is offline   Reply With Quote
Old 8th Oct 2016, 18:57   #38
Deblow
Supermodder
Deblow's Avatar
For the side panel i'm going with one that's airbrushed and also doing a plain one painted the same as the rest of the case.
I'm doing the airbrushing in 3 stages, first the panel was painted the same as all the case but then sanded down ready
for the shadows and base colours, protected again with some clear coat and then stage 2, now I have clear coated all
the design and will be waiting for that to harden before doing the highlights and fine details followed by a final protective
clear coat.
Some parts of the design will hopefully have a matte look where others will be a nice mirror/gloss finish
to help him pop-out from the back background.
This might look a bit crap at the moment but should look great when completed, I like to try use as many skills as I can when
doing my builds, this is something I've never attempted before so i'm learning as I go along
As promised, here are some pics of the smaller project I just completed "Tron 2.0" this was just a case mod for now, using the
CoolerMaster MasterCase 3 Pro.
No log for this one, it was a very quick job with only the paint dry times taking most of that time up.
Done in white with slightly thicker EL wires and the same Mirror finish paint but this time in white.
I wont post lots of photos on here but you can find all the other on my facebook page if you need.
Thanks to elpanelandtape.co.uk and CoolerMaster UK for providing most of the bits needed for this one.
Old 12th Oct 2016, 16:23   #39
Deblow
Supermodder
Deblow's Avatar
arh, French curves, looking sweet
Thanks
Old 19th Oct 2016, 17:44   #40
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
That is one seriously cool looking mod.
bulldogjeff is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
