Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 12th Sep 2016, 10:46   #1
Abbo
ATi or Nvidia?
Abbo has yet to learn the way of the Dremel
Time for new Motherboard?
Hi All
Looking for some advice. My system is as below:
Motherboard - ASUS P7P55D Deluxe
CPU - Intel i7 -860 2.8- GHz
GPU - ASUS STRIX-R9 390-DC3 8GB
RAM - Corsair Dominator GT 8GB (4 x 2GB)
O/S HDD - Sandisk Ultra II 960GB SSD
Internal Storage - Samsung Spinpoint F1 1TB x 5
PSU - Corsair HX10000W
Case - Antec 1200
Logitech G19 Keyboard
I undgraded to Windows 10 when the free upgrade happened ages ago. More recently I have been running out of O/S HDD space, so got a 960GB SSD. Installed that this weekend and have been rebuilding. No real problem, but have been experiencing a CPU overheat message when I boot. Doesn't always come up, but looking in the BIOS, the CPU has a temp of 98 degrees C. Thought that's a bit high. I am going to check my motherboard to make sure there is nothing wrong with he CPU fan. In parallel to this, I was also trying to install the software/utilities for the Asus motherboard, and noticed there are no Win10 versions. I know the board is some years old now, but neither of the Win7 or Win 8 versions work either. I was hoping to look at one of the utilities to try to pin point the CPU overheating issue.
Does it look like there is an issue with the CPU? Or just that the fan can't be controlled properly? Is it time for a new CPU and motherboard?
Thanks.
Abbo is offline   Reply With Quote
Old 16th Sep 2016, 14:18   #2
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Apologies you are having issues. Have you tried installing CPU-Z or Speedfan to check your CPU temperatures? You should be able to adjust the fan speed in the bios on the fan curve settings. Also are you overclocking the CPU and or using a stock cooler?
Kind Regards.
Will_ASUSUK is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
