Reply
Thread Tools View Mode
Old 12th Nov 2016, 18:31   #21
MegaSkot
Multimodder
MegaSkot's Avatar
MegaSkot has yet to learn the way of the Dremel
Hahahahahaah
__________________
MegaSkot is offline   Reply With Quote
Old 2nd Dec 2016, 10:23   #22
MegaSkot
Multimodder
MegaSkot's Avatar
__________________
Old 3rd Dec 2016, 22:15   #23
MegaSkot
Multimodder
MegaSkot's Avatar
Asus Rampage V Edition 10
+Intel i7-6800K
+EK-FB ASUS R5-E10 Monoblock RGB Edition
+EK-HDC Fitting 16mm G1/4 - Red.
__________________
Old 4th Dec 2016, 21:47   #24
MegaSkot
Multimodder
MegaSkot's Avatar
MB holder and water cooling pipes, all in one.
Now I need to insert Cu pipes in alu frame.
__________________
Old 6th Dec 2016, 00:08   #25
MegaSkot
Multimodder
MegaSkot's Avatar
Progress...
__________________
Old 12th Dec 2016, 04:50   #26
MegaSkot
Multimodder
MegaSkot's Avatar
Progress...
__________________
Old 13th Dec 2016, 09:14   #27
MegaSkot
Multimodder
MegaSkot's Avatar
Finally arrived alu pipe 60/5 for chair.
__________________
Old 14th Dec 2016, 02:18   #28
MegaSkot
Multimodder
MegaSkot's Avatar
Radiator covers.
__________________
Old 19th Dec 2016, 10:44   #29
MegaSkot
Multimodder
MegaSkot's Avatar
Speakers and DVD/RW for chair.
__________________
Old 19th Dec 2016, 12:35   #30
eucalyptus
I am 19 and Swedish!
eucalyptus's Avatar
eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.
Looking good buddy
I don't know if I missed anything, but are the pc components and water cooling going be built in, combined with the chair?
Wish I had a welder too, possibilities are just incredible!
__________________
Project Three Leaves / Build log / Galleries - Daylight / Night Vision / My setup
V8 Ocean / Build log
Follow- or send me a message on Facebook /Sebastian Edemalm
eucalyptus is offline   Reply With Quote
Old 19th Dec 2016, 21:04   #31
MegaSkot
Multimodder
MegaSkot's Avatar
Yes, all will be welded together.
__________________
Old 20th Dec 2016, 17:07   #32
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
All that soldering... That's no picnic. That would be impossible for me with my crummy propane torch.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 3rd Feb 2017, 02:21   #33
MegaSkot
Multimodder
MegaSkot's Avatar
Update:
__________________
Old 4th Feb 2017, 17:36   #34
MegaSkot
Multimodder
MegaSkot's Avatar
Speakers.
__________________
Old 5th Feb 2017, 00:25   #35
MegaSkot
Multimodder
MegaSkot's Avatar
EK-CoolStream XE 360 cover.
__________________
Old 10th Mar 2017, 18:02   #36
MegaSkot
Multimodder
MegaSkot's Avatar
Full custom-made leather seat (made of black real leather, stiched with red threads).
__________________
Old 10th Mar 2017, 21:25   #37
Vault-Tec
Banned
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Wow that leather is amazing
Vault-Tec is online now   Reply With Quote
Old 20th Mar 2017, 08:36   #38
MegaSkot
Multimodder
MegaSkot's Avatar
Thanks.
__________________
Old 20th Mar 2017, 09:35   #39
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
this is insanely cool!
Keep the updates coming
__________________
storm-83 is offline   Reply With Quote
Old 21st Mar 2017, 18:09   #40
GeneralFun
Lurker with tools
GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.GeneralFun is definitely a rep cheat.
I love overkill! Incredible!
__________________
I genuinely become interested when someone says
" There's no way to do that!"
ASUS Sabertooth Mark 1, GTX1080, I7-6700K, DarkRockPro 3, Corsair Vengance DDR4 3200, LIAN-LI PC-P80, Dell 2716DG
GeneralFun is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
