Old 11th Oct 2016, 21:27   #1
Goofy Flow
What's a Dremel?
Goofy Flow has yet to learn the way of the Dremel
PARVUM JAWS
I'm so excited to start a new build with the support of awesome guys from Parvum Systems which I'd like to thank for their work and for their willingness, what else brand in the world is so attentive to own customer? Not many I would say!
This build is dedicated at one of the best films of all time, at least for me but I hope for you too, and one of the most famous Spielberg's movie, Jaws.
The basic idea is inspired by one of my favorite build ever, called "Xenomorph" of Akira749, namely to recreate the features of a creature / monster / villain (the xenomorph in the akira's build and the shark in mine) and the "atmospheres" of the movie.
First, I explained to Justin my ideas for the subject and for the most suitable color scheme, then he designed the render in my place.
The case is rich of details, the shark bites are just what I wanted, they give a very personalized look to the entire case, the movie logo is the cherry on the cake.
Main Components
WIP
Watercooling Components
WIP
Miscellaneous
WIP
Timelines
Rendering
Goofy Flow is offline   Reply With Quote
Old 12th Oct 2016, 10:15   #2
jojoharalds
Supermodder
jojoharalds's Avatar
jojoharalds has yet to learn the way of the Dremel
This looks badass!!
And yes the guys over @ Parvum Systems are AWSOME!!
jojoharalds is offline   Reply With Quote
Old 18th Oct 2016, 23:29   #3
Goofy Flow
What's a Dremel?
Start with a little close up of the brass cubes
The light which come off from the cubes remind me in some way the headlight of a boat at night
Old 22nd Oct 2016, 19:54   #4
Goofy Flow
What's a Dremel?
Detail of the logo (the characters are the original of the movie logo)
Ok now before mounting the case, I placed the panels one by one for cleaning and with a bit of patience, I make this photo
Front panel with 3 layers
Rear panel with 2 layers
Base panel with 1 layer
Main panel
Top panel with 2 layers
Back side panel with 1 layer
Window side panel with 2 layers
Pci-e bracket
SSD/HDD plate
Parvum Systems fan (only one but it's a gift, thank you guys)
Old 1st Nov 2016, 20:25   #5
Goofy Flow
What's a Dremel?
Ok, I mounted the case and I created a "panel by panel" time-lapse, unfortunately the GIF file doesn't have a good quality but I think it's fine.
The effect is not perfect because the shadows, exposure and backdrop always change, but I did my best
Front side
Rear side
Bonus pic
Old 2nd Nov 2016, 08:03   #6
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
nice colors on the panels
looking forward to seeing some hardware in this thing
* edit *
i would have suspected that jaws was going to gobble the reservoir, but (sadly) i see a transparent sheet there...
__________________
storm-83 is offline   Reply With Quote
Old 2nd Nov 2016, 10:50   #7
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
We're gonna need a bigger case
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 11th Nov 2016, 19:09   #8
Goofy Flow
What's a Dremel?
* edit *
Thank you
What do you mean "was going to gobble the reservoir"?
Old 11th Nov 2016, 19:13   #9
Goofy Flow
What's a Dremel?
Old 12th Nov 2016, 17:42   #10
storm-83
Supermodder
storm-83's Avatar
In the movie, they blow up the shark by making it bite a gas canister. would be cool if the canister was the reservoir!
__________________
Old 26th Feb 2017, 22:49   #11
Goofy Flow
What's a Dremel?
UPDATE
Ok, I recently receive the panels, (a new main panel because the previous had many bubbles and a new third panels for the front) and after the huge stop, finally I can continue the build
Old 27th Feb 2017, 08:24   #12
Hukkel
James' minion
Hukkel's Avatar
Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.
Nice design concept
__________________
Facebook page
Hukkel is offline   Reply With Quote
Old 28th Feb 2017, 11:41   #13
Goofy Flow
What's a Dremel?
Originally Posted by Hukkel View Post
Nice design concept
Thanks
Old 20th Mar 2017, 19:17   #14
Goofy Flow
What's a Dremel?
Now is time to choose the color pattern for the sleeving, which must fits the theme and "dark environment" like abyss or deep water, black and dark blue for "recreate" the deep water environment, grey to match the logo and shark skin.
This is what I choose at the moment, suggestion are welcome (pay no attention at the red logos of the mobo)
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
