Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 16th Nov 2016, 20:50   #1
Shanx
Minimodder
Shanx's Avatar
Shanx has yet to learn the way of the Dremel
Windows 8.1 install problem
I thought it would be a good idea to upgrade to windows 8 from vista.
So bought a digital copy and created the necessary ISO file from the MS.site onto a USB stick.
Turned on the pc, inserted USB and followed instructions, formatted the HD and all started well got to 79% and the error. Apparently some drivers were missing. So went on line to find drivers but no luck.
So thought maybe I had a dodgy download so decided to burn a new ISO file to DVD, inserted DVD with the hope of find it had the relevent drivers no luck.
Didn't know what to do next, so stupidly I shut down the pc with a view to investigate further and solve the problem.
Now I have a brick for a pc and a screen that keeps telling me to insert the installation disc restart the pc and repair the pc all of which I can't do.
I can't even reload Vista from the OEM disc I bought when I built the pc.
If anyone has any suggestions on how to remedy the issue, if at all possible, I would be extremely grateful.
Yours in hope
Shanx
Shanx is offline   Reply With Quote
Old 16th Nov 2016, 20:57   #2
wolfticket
Downwind from the bloodhounds
wolfticket's Avatar
wolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyanwolfticket is a Super Spamming Saiyan
I don't think Microsoft currently sell a digital version of 8.1. As far as I can tell you can only buy 10 now.
__________________
Wolfticket: Ambitious but rubbish
"A facility for quotation covers the absence of original thought."
Dorothy L. Sayers (1893 - 1957)
wolfticket is offline   Reply With Quote
Old 16th Nov 2016, 21:06   #3
Shanx
Minimodder
Shanx's Avatar
No they don't, I bought it from Play Asia you get a valid 25 digit key code and they direct to Microsoft to download the ISO file for the relevant version of windows.
Old 17th Nov 2016, 14:21   #4
wolfticket
wolfticket's Avatar
I'd be concerned about sourcing a windows licence like that on the "if it seems to be too good to be true" rule. Also I wouldn't be installing 8.1 at this point in proceedings. Either 10, of if you really want to, 7.
That said, Windows 8.1 should install without any licence at all so that should rule out any licence issues.
If you have access to another system then I'd download 8.1 again from here and try a fresh install again, deleting all partitions and reformatting in the process.
It could have been a bad download or image creation.
I would say you might need SATA drivers but it sounds like the install process has gone well beyond that stage already so that shouldn't be the issue.
If your system is as here: http://forums.bit-tech.net/showthrea...71#post4188571 then I really can't think off the top of my head why you should have any real problems installing 8.1.
__________________
Old 17th Nov 2016, 15:25   #5
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
My guess would be HDD is having a mare. Get it tested with something like gsmartcontrol in a different PC.
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 17th Nov 2016, 18:05   #6
Shanx
Minimodder
Shanx's Avatar
wolfticket
Yes that is my current system and the link you put up takes me to the same Microsoft site that Play Asia directed me to to download the ISO file. It had completed 79% of the 2nd stage then the error message.
noizdaemon
I don't have another PC to test it on, so i have decided to take it to a local independent PC shop a mate of mine recommends and get them to test it, but thanks for the advice.
Thanks again for the advice.
Shanx
Old 17th Nov 2016, 18:09   #7
wolfticket
wolfticket's Avatar
Originally Posted by Shanx View Post
wolfticket
I figured it would be the same site. Sometimes downloads or images can become corrupted though. I was suggesting you download and create the install media again.
__________________
Old 17th Nov 2016, 19:42   #8
Shanx
Minimodder
Shanx's Avatar
Doh 😳 Re engage brain. I'll give it a go & see what happens 👍🏻
Thanks again
Old 18th Nov 2016, 15:13   #9
Shanx
Minimodder
Shanx's Avatar
Well with much tinkering and fiddling with the bios I finally managed to coax the pc into reloading Vista,not what I really wanted but no matter what I did it would not load window 8.1.
My thanks to noizdaemon for the link to Rufus, I tried that with a new download of the ISO but the stubborn pc didn't want to know.
Not sure what to do now, the main reason for the software upgrade was to combat all the 'browser not compatible' issues I keep getting and the fact the pc was so slow I thought that it would also serve the purpose of getting rid of all the crap that has accumulated in 8+ years that it has been in use.
Thanks again for the help and advice.
Shanx
Old 27th Nov 2016, 16:16   #10
Wolfe33
What's a Dremel?
Wolfe33 has yet to learn the way of the Dremel
Watch this video https://www.youtube.com/watch?v=nf8Kg3BT_kw
Wolfe33 is offline   Reply With Quote
Old 28th Nov 2016, 13:56   #11
noizdaemon666
Originally Posted by Wolfe33 View Post
That is possibly the most pointless video I've ever seen. How is anyone meant to run setup from within the SXS folder when they probably won't have an OS installed? And beyond that, I still don't see how it would help.
__________________
Old 3rd Dec 2016, 19:20   #12
Shanx
Minimodder
Shanx's Avatar
Couldn't agree more, with no OS installed totally pointless post.
Thanks again for the earlier advice, went to the local Indy pc shop recommended by a mate and they sorted the issue and install 8.1 for me.
Now works a treat 👍😀
Old 4th Dec 2016, 06:28   #13
spolsh
Supermodder
spolsh's Avatar
spolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyan
Did they say what had caused the issue ?
__________________
GeIL has yet to confirm UK availability and pricing.
spolsh is offline   Reply With Quote
Old 5th Dec 2016, 16:43   #14
Shanx
Minimodder
Shanx's Avatar
No - TBH i didn't think to ask .
They tested all the hardware first and found no issues so I just put it down to a dodgy ISO file and my messing around after it failed to initially load 8.1.
Just happy to have it working again
Got myself an extra 4Gb of Corsair 1066Ghz RAM bringing it up to 8Gb so should see me right for a couple of years or so until I can afford to upgrade.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
