Reply
Thread Tools View Mode
Old 17th Nov 2016, 18:20   #1
huckinCharlie
Charlie
huckinCharlie's Avatar
huckinCharlie has yet to learn the way of the Dremel
Copper One - Scratch PC
So here we are
my last project - handmade full aluminum halfunibody lc loop is made with borosilicate glass tubes
https://www.facebook.com/onebycharlie/
Now new project.
Leitmotive - copper So now I'm cutiing on cnc new version of case (inverted).
best of the best SPONSORS:
huckinCharlie is offline   Reply With Quote
Old 19th Nov 2016, 18:31   #2
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Pretty.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 23rd Nov 2016, 14:44   #3
huckinCharlie
Charlie
So, I'm still working
You can see outline of inverted atx and some modifications. More pix any day now.
Old 23rd Nov 2016, 15:27   #4
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
It looks like a Parvum....
Just joshing. I like it. Clean to the point of being clinical but I like how the inside kinda looks like a Caselabs with plenty of room
Like the mix of tubing too. That's very inventive
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 23rd Nov 2016, 15:55   #5
spigs_rex
Multimodder
spigs_rex has yet to learn the way of the Dremel
parvum meets TJ07 ...looks like its gonna be a very nice build, this might be a stupid question, but how do you stop copper from oxidising/will it oxidise?
spigs_rex is offline   Reply With Quote
Old 23rd Nov 2016, 16:58   #6
huckinCharlie
Charlie
tubing wouldn't be mixed only copper tubing
Originally Posted by spigs_rex View Post
... this might be a stupid question, but how do you stop copper from oxidising/will it oxidise?
first passivation and then maybe rostoleum
Old 29th Nov 2016, 17:34   #7
huckinCharlie
Charlie
little teaser
brothers
still a lot of work
Old 30th Nov 2016, 19:35   #8
huckinCharlie
Charlie
guys, it's happenning
Old 4th Dec 2016, 16:33   #9
huckinCharlie
Charlie
In the meantime. Perfectly shaped glass pipes.
Old 12th Dec 2016, 19:28   #10
huckinCharlie
Charlie
so next one < haters gonna hate >
Old 12th Dec 2016, 23:05   #11
C4B12
Minimalistic PC's
C4B12's Avatar
C4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on you
Interesting! Looking forward to more updates.
__________________
Scratch builds | The Red One | Cold Winter | CURV3D | C.ACE | SAIL |
Casemods | BarPC | F4DE | Spec-Edge |
Check out Minimalistic PC for news about modding and different projects!
C4B12 is offline   Reply With Quote
Old 29th Dec 2016, 19:48   #12
huckinCharlie
Charlie
working, slowly
Old 29th Dec 2016, 20:00   #13
Vault-Tec
Vault-Tec's Avatar
Drool.
__________________
MUWC Winner ROTT
Old 23rd Jan 2017, 17:55   #14
huckinCharlie
Charlie
Finally: the right way
Old 27th Jan 2017, 15:31   #15
huckinCharlie
Charlie
closer and closer
Old 30th Jan 2017, 18:02   #16
huckinCharlie
Charlie
next step
Old 8th Feb 2017, 18:05   #17
davido_labido
Staff
bit-tech Staff
davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.
Very nice start to the build, so much so I added to this months Modding Update!
https://www.bit-tech.net/modding/mod...january-2017/1
very interested to see the finished mod!
davido_labido is offline   Reply With Quote
Old 9th Feb 2017, 19:44   #18
huckinCharlie
Charlie
@davido_labido
Old 9th Feb 2017, 19:50   #19
huckinCharlie
Charlie
small hardware update guys
Old 13th Feb 2017, 17:21   #20
huckinCharlie
Charlie
small update
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
