Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 20th Nov 2016, 13:37   #1
dinoscothern
Multimodder
dinoscothern has yet to learn the way of the Dremel
Older generation mb boot Linux off m.2 nvme drive?
After searching the internet and getting conflicting reports I would like to ask here.
Has anyone had personal experience with booting Linux from a m.2 nvme drive in an adapter card
on an (ASUS) X79 motherboard (say P9X79 LE or P9X79E-WS)?
It seems that some have managed to boot from it in non efi/legacy mode.
Others have patched their bios, adding a nvme module.
I don't want to buy one of the newer samsung drives and find I can only use it as a non boot drive.
dinoscothern is offline   Reply With Quote
Old 20th Nov 2016, 14:21   #2
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
It's doable, but a bit fiddly...
Some boards have to be put in Legacy [not UEFI] mode to work, and in some cases you have to format it in the command line before the installer will recognise it as a drive it can install to.
This shows someone doing exactly that, albeit on a Z87 board.
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 20th Nov 2016, 15:59   #3
dinoscothern
Multimodder
Thanks.
This is the link to an article on modifying the EFI bios.
Old 17th Dec 2016, 22:29   #4
dinoscothern
Multimodder
Phew I finally got this to work with a SM961, adding the nvme efi module to my gigabyte X79-UD3 F20 bios before I flashed it. It seems that my main problem was with the Xubuntu 16.04.1 installer, which imo is a bit rubbish (note to self: the quit button escapes to the desktop where I can do things manually in a terminal)
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
