Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 23rd Nov 2016, 14:11   #1
Xaine
Death... destroyer of brain cells
Xaine's Avatar
Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.Xaine is definitely a rep cheat.
Windows main drive cloning to M.2
Heya folks, my first post in this particular section.
I'm helping a friend build a PC and his current has windows 10 on it, it was the free one that happened a while back.
The build in question has a nice Sammy M.2 in it for the main drive and I'm curiois whether we can save him 90 quid and get his current system on the new M.2 or better yet fresh install and use current key.
Is this possible and if so any links on the process?
Thank in advance
__________________
I have irradiated my pants... HULK OUT!
i7 4790k, MSI Z87 G45 Gaming, H100i, HX850i, ASUS Strix 1080 Advanced, 250 840 Evo, 8gb Avexir Blitz DC 2133mhz C9 & Bunch of fancy fans
Xaine is offline   Reply With Quote
Old 23rd Nov 2016, 14:19   #2
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Reload it. It will save a lot of hassle. It will likely just activate after the reload if you're only swapping one major component. If not, find his old key and activate using that.
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 23rd Nov 2016, 14:34   #3
Xaine
Xaine's Avatar
Not swapping one component, all of them, and as its the free version will it have a key he can access?
__________________
Old 23rd Nov 2016, 14:42   #4
noizdaemon666
No, that isn't how Windows 10 activation works (unless you purchased a key and even then you don't 100% need to keep hold of it). Windows 10 essentially creates a unique key based on your current hardware and registers it with Microsoft as activated. Change more than 3 components (as you're doing) and you'll need to reactivate; the easiest way is to simply re-enter his old Windows7/8 key. Otherwise, it's purchase a new key time.
__________________
Old 23rd Nov 2016, 14:54   #5
Xaine
Xaine's Avatar
I've clarifies some things with him and he upgraded from windows 7 so will likely have the activation key somewhere, so just need to find that and jobs a goodun.
Thank you very much for the info kind sir
__________________
Old 23rd Nov 2016, 15:10   #6
noizdaemon666
Just as an addendum; don't enter the key during install. Enter it after everything is up and running
__________________
Old 23rd Nov 2016, 15:15   #7
Xaine
Xaine's Avatar
Good call thanks
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
