Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 26th Nov 2016, 18:29   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
onboard display port not showing
Any ideas of how I can get my onboard display port to work- I have got a MSI Z97 Gaming M motherboard which I am trying to install clean windows 10 but I get no signal from onboard
However, if I put in my GTX 1080, it displays fine.
I tried going into BIOS and setting the GPU to IGU but nothing
Any ideas good folk of bit-tech land
hairyknacker is offline   Reply With Quote
Old 27th Nov 2016, 15:22   #2
hairyknacker
Multimodder
No one?
Old 28th Nov 2016, 01:16   #3
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
If there isn't an option somewhere in the BIOS, or a DIP switch on the motherboard or something... I can't think of anything offhand other than a duff port on the mobo. Even if it's an 'old' standard, it should still work - just at reduced res or refresh rate.
Compressed air at the port to try blowing any dust out? Making sure the computer is thoroughly power-off (unplugged, hit power button once unplugged) try cleaning the port gently?
I've never used the iGPU on Z97, always using a dGPU.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
