Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 27th Nov 2016, 14:22   #1
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
How to force a format in Windows 7?
I've got a second disk installed on my new desktop that I am trying to format, but nothing is working. I tried running the format command from the command prompt and it said
"Format cannot run because the volume is in use by another process. Format may run if the volume is dismounted first. ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID. Would you like to force a dismount on this volume?"
I said yes
"Cannot lock the drive. The volume is still in use."
I then tried rebooting the system and got the same result.
I also tried formatting it from Windows Explorer, but got an error message that says
"Windows cannot format this drive. Quit any disk utilities or other programs that are using this drive and make sure that no window is displaying the contents of this drive. Then try formatting again"
Where do I go from here?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 27th Nov 2016, 15:15   #2
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
Go into disk management and right click the drive, should be Disc 1 (in the bottom section) then select offline.
Instruction linky.
Corky42 is online now   Reply With Quote
Old 27th Nov 2016, 17:55   #3
Cthippo
Cthippo's Avatar
Ok, tried that, didn't work.
in the GUI Disk management program the "offline" option is greyed out and in the command line tool it says that "The operation is not allowed on a disk that contains a pagefile volume."
This disk was has a previous install of Win7 on it and after deleting everything I could, it stills shows 17.5 GB of used space on the disk, appearently in hidden files.
__________________
Old 27th Nov 2016, 18:00   #4
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
burn it all and start over in diskpart?
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 27th Nov 2016, 19:50   #5
spolsh
Supermodder
spolsh's Avatar
spolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyanspolsh is a Super Spamming Saiyan
If you have one, try from a USB enclosure, then install the disk.
__________________
GeIL has yet to confirm UK availability and pricing.
spolsh is offline   Reply With Quote
Old 27th Nov 2016, 20:03   #6
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Ubuntu live USB and Gparted.
theshadow2001 is offline   Reply With Quote
Old 27th Nov 2016, 21:00   #7
sparkyboy22
Web Tinkerer
sparkyboy22's Avatar
sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.sparkyboy22 is the Cheesecake. Relix smiles down upon them.
Cmd
Diskpart
List disks
Select disk X (don't pick the wrong one!)
Clean
Exit
Exit
__________________
i5 2500k @ 4.5 GHz | Corsair H100 | Asus P8P67 Pro | 16GB Corsair Vengeance | EVGA GTX680 | Corsair Force 3 240GB SSD
Corsair HX650 | Xigmatek Utgard | 27" LG Something or other
Logitech Z906 5.1 Speakers | Logitech K750 Solar Keyboard | Logitech Performance MX Mouse
sparkyboy22 is offline   Reply With Quote
Old 27th Nov 2016, 21:22   #8
play_boy_2000
It was funny when I was 12
play_boy_2000's Avatar
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
Sounds like windows automatically started using the drive for a page file.
Right-click Computer.
Select Properties.
Select Advanced system settings.
Select the Advanced tab and then the Performance radio button.
Select the Change box under Virtual memory.
Un-check Automatically manage paging file size for all drives.
Remove paging from the offending drive.
Profit??
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Old 28th Nov 2016, 04:03   #9
Cthippo
Cthippo's Avatar
Select Properties.
Profit??
Aha, that finally got it to a point where I could format it. Thanks all!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
