Reply
Thread Tools View Mode
Old 28th Nov 2016, 08:42   #1
ciobanulx
Modder / Watercooler
ciobanulx's Avatar
ciobanulx has yet to learn the way of the Dremel
570TRIX (modded Corsair 570X) by SimpleModz
Hi guys,
Welcome back to another one of my build logs! This time I am working on the newly released Corsair Crystal 570X tempered glass case!
I would like to thank everyone at Corsair for giving me the opportunity to work on this case as I know this was sent to a group of elite modders world wide! I'm simply honored to be considered for this and see myself up there with the talented people that I look up to and inspire my work!
The 570X is a case with tempered glass on pretty much all sides and it's truly a stunning case. My build will be all about elegance and luxury as well as drawing a bit of inspiration from the crystal series name.
SPECS:
Case Corsair Crystal 570X
Motherboard TBA
CPU TBA
Memory 4 x 4GB Corsair Dominator Platinum 3000Mhz DDR4 RAM
GPU TBA
SSD 240GB Corsair Force LE SSD
PSU TBA
Custom Cables - CableMod
Cooling
Corsair H100i V2
Corsair HD120 RGB Fans
To start off the build log I did a quick unboxing presentation of the case. I hope you guys enjoy it and stay tuned for more!
Cheers,
Alex
ciobanulx is offline   Reply With Quote
Old 5th Dec 2016, 08:26   #2
ciobanulx
ciobanulx's Avatar
Hey guys,
Time to start making some progress on this build so I started stripping down the case.
Next step will be to fully take it apart by drilling out all the rivets however I need to work on some things before.
More to come
A great thing about the 570X is that you can take both the front and top fan/rad mount out by just undoing two thumb screws.
This then leaves the top and front fully open.
Stay tuned for more!
Cheers,
Alex
Old 8th Dec 2016, 07:42   #3
ciobanulx
ciobanulx's Avatar
Hey guys,
I've been working on my design for this build and ended up cutting a lot of acrylic for it.
Here's the near entire pile hahaha. I'm still working on my idea and refining it but I think it should turn out pretty nice.
Different panel sections that I am working on
This will be on the back to hide some cables and the rest will be displayed nicely behind the motherboard tray through the tempered glass panel.
I have them numbered and named hahaha as there are so many of them.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
Old 12th Dec 2016, 07:53   #4
ciobanulx
ciobanulx's Avatar
Hey guys,
I've started to take apart the case and get it ready for painting. So many rivets!
Cheers,
Alex
Old 13th Dec 2016, 07:37   #5
ciobanulx
ciobanulx's Avatar
Scuffed and ready for painting!
See if you can guess the colour! It's not black like the cap suggests :P
Old 16th Dec 2016, 11:27   #6
ciobanulx
ciobanulx's Avatar
Hey guys,
The custom paint for the main panels is now finished! The parts that are still black are scuffed as I was going to do them silver as well however I decided to leave them and it works out better this way. I will just need to re-spray them black now in order to fix up the scuffing.
Anyways, let me know what you think so far! Stay tuned as there's more to come!
Thanks for checking it out!
Cheers,
Alex
Old 25th Dec 2016, 12:05   #7
ciobanulx
ciobanulx's Avatar
Hi guys,
Merry Christmas! Just wanted to do a quick update on the build
With the majority of the case work now finished I will have to turn to the smaller details now and you guys will get to see that in due time.
Before that I want to showcase some of the components, the new H100i v2 and the Corsair HD120RGB fans. I am very excited for getting to use these fans
I'll have more updates in the new year or sooner if I can
Cheers,
Alex
Old 28th Dec 2016, 12:21   #8
ciobanulx
ciobanulx's Avatar
Hi guys,
A quick update on the PSU shroud design I am doing
Just needs a bit of a clean up and some clear coat
Cheers,
Alex
Old 30th Dec 2016, 12:22   #9
ciobanulx
ciobanulx's Avatar
Hi guys,
I have a few more photos to share on the project however beyond this point I can't really share much due to NDA stuff. The build will be finished shortly and very soon I will be able to show everything so stay tuned.
I have most of the core components in at this point. I just need to finish the rest of the panels for the case and a special effect for the outside glass panels. Half of the cable management is done as well with all the fans and H100 cables sorted. There will be a cover panel going over this area which I shared before.
Cheers,
Alex
Old 9th Jan 2017, 05:58   #10
ciobanulx
ciobanulx's Avatar
Hey guys,
The build is nearly finished and now that Kaby Lake and Z270 is out I can share a bit more of the progress
The motherboard being used is the new ASUS ROG STRIX Z270E and the CPU is the new i7 7700K.
Check out the progress pics.
Also here's a sneak peak at the awesome laser etching done on the glass with the help of my good friend Stephen from Oz Modz.
Stay tuned for final pics.
Thanks for checking it out.
Cheers,
Alex
Old 20th Mar 2017, 09:08   #11
ciobanulx
ciobanulx's Avatar
Hey guys,
It's been a while since I posted on the forums
I finished the build in early January and then shipped it off to Corsair HQ before heading on a much needed holiday to the USA (my first time there). I had an awesome time there and I also got to actually visit Corsair HQ in Fremont which was definitely one of the highlights and a big honor. I'll have some pics to share in here for those interested to see.
I've been back for about a month now and slowly starting to get back into things but also super busy. I'll shortly have some more build logs up as I'm currently working on 3 builds at the same time. But first, I just realised that I never finished this build log with final pics, so here they are!
Hope you guys like it, if you haven't seen it anywhere else by now :P
Cheers,
Alex
Old 22nd Mar 2017, 08:22   #12
ciobanulx
ciobanulx's Avatar
Hey guys,
Here are a few more photos of the inside and also with a different colour on the fans
Cheers,
Alex
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
