Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 8th Dec 2016, 20:55   #1
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Win 10 content specific folders
Win 10 has content specific folders, so in a "normal" folder I'd see:
Name Last-change-date Type Size
now if there's music in there its:
Name Title-number Title Artist Album
Folders containing pictures are different again
And so on...
it bugs me.
Is there a SIMPLE way to change all to default Name Last-change-date Type Size?
So not go into every foldertype imaginable and change the settings for all similar, but change all folderviews?
Thx,
Xir
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is online now   Reply With Quote
Old 8th Dec 2016, 21:08   #2
RedFlames
...is a figment of your imagination
RedFlames's Avatar
RedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming SaiyanRedFlames is a Super Spamming Saiyan
Folder Properties -> Customise
'Optimise this folder for:' -> 'General Items'
Tick 'Apply this template to subfolders'
Apply
[If 'Customise' tab isn't there, you don't have correct folder permissions. which is sometimes an issue when you try and do entire drive at once.]
__________________
Why are you still reading this? The post is over. Go Home.
RedFlames is offline   Reply With Quote
Old 8th Dec 2016, 22:00   #3
Xir
Xir's Avatar
Thank you!
Worked for the entire drive
__________________
SN25P
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
