Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 10th Dec 2016, 21:46   #1
Mr_Mistoffelees
More Spanners Please.
Mr_Mistoffelees's Avatar
Mr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming SaiyanMr_Mistoffelees is a Super Spamming Saiyan
Windows 10 activation after hardware changes.
In a few days, following a motherboard failure, I will be rebuilding my PC with a new motherboard, RAM and CPU. Are Microsoft likely to look favourably on my being allowed to continue to use my W10 digital license? W7 license, before upgrade, was OEM.
__________________
Your Spanners Need You!
Mr_Mistoffelees is offline   Reply With Quote
Old 10th Dec 2016, 22:07   #2
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
It will more than likely fail automatic activation, but I've re-activated OEM releases using the telephone service - dead easy with a smart phone now too.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|GTX 980|3007WFP-HC|Parvum S2.0
David is offline   Reply With Quote
Old 11th Dec 2016, 11:41   #3
13eightyfour
Formerly Titanium Angel
13eightyfour's Avatar
13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan13eightyfour is a Super Spamming Saiyan
I swapped out my Mobo a few weeks ago, which caused the system to fail automatic activation, all I had to do was enter the email/password assigned to MS and it activated over the internet without any issues.
13eightyfour is offline   Reply With Quote
Old 11th Dec 2016, 16:44   #4
MadGinga
I *am* a Dremel
MadGinga's Avatar
MadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming Saiyan
I dunno, I just swapped mobo, cpu, and ram, and added 4 HDDs, plugged it all in and not a peep from Win10, so go figure...
__________________
Gaming: i5-3570K | P8Z77-V | HyperX 4x4GB | 850 Evo 250GB | WD 1TB | EVGA GTX980ti SC | SB Xi-Fi | Define R5 | CM TX650M | Win 7 Ultimate | U2412M | Ducky Shine 5 RGB (Brown) | Logitech MX Master
Office: i3-3220 | H61M-K | 2x4GB | 120GB SSD | 120GB | HD7870 2GB | Elite 342 | CX600M | Win 7 | MS Desktop 600 | Logitech M185
Server: i5-3540 | P8H77-M | 2x4GB | 120GB SSD | 2TB, 2x3TB, 2x4TB | Define R5 | EVGA 500B | Win 10 | Logitech K400+ & M185
MadGinga is offline   Reply With Quote
Old 11th Dec 2016, 16:55   #5
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
I think it depends on your key. Retail keys allow you to use more than one PC per key. If you only have one then all you would need to do in theory is activate it on the new gear which would then disable your old one. I usually use the phone method.
But yeah, no key will "die" or what not because you switched hardware. Well, not unless some one else has the same key as you.
AFAIK keys from Dell Alienware HP etc are all single use keys. Retail keys allow you to activate on more than one PC
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 12th Dec 2016, 13:54   #6
Mr_Mistoffelees
Seems hopefull but, if all else fails, hello Ubuntu. Can't go spending money on a new Windows license at the moment.
__________________
Old 13th Dec 2016, 14:32   #7
Vault-Tec
Vault-Tec's Avatar
You should be fine, just do the phone thang.
Recently I crumbled and bought a 8.1 key from a mate who had bought it from a key site. I wanted my rigs as genuine as possible so I bought the key for a tenner. It refused to go on at first, saying it was in use so I did the phone thing and it's been running 10 ever since. That was oo, about four to five months ago?
Only major risk with those sorts of serials is the seller gets greedy and sells them multiple times.
My Alienware 8.1 key became a 10 key after using it for a certain amount of time (can't go back now apparently) and I've had no issues with that either and can now just straight install 10 on that one.
__________________
MUWC Winner ROTT
Old 21st Dec 2016, 00:16   #8
Mr_Mistoffelees
Rebuilt PC yesterday and tried to activate in the evening. No Microsoft phone service that late so had to do chat but, after much faffing, they gave me a new code and so all is well and activated.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
