Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 13th Dec 2016, 14:46   #1
GaryP
RIP Tel
GaryP's Avatar
GaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming SaiyanGaryP is a Super Spamming Saiyan
Any PHP programmers here ?
I am not sure if this is in the right section but here goes.
I have just taken over the running of a sports club website that uses asp. The site is run on a custom built management system using mySQL that outputs in asp. Basically I want (someone) to rebuild the backend so that I can rebuild the site using php.
I have just started rebuilding the front end as it was all built using tables, and so I am recoding properly and using css to style.
The backend is a fairly extensive set up so of course I would get the club concerned to pay you. I just need an idea if it can be done and an idea of the cost.
__________________
Intel i7 5820k @ 4.3Ghz | Corsair H110i GT | 16GB G Skill Ripjaws 4 3200Mhz | MSI Titanium X99A | Corsair AX 760 PSU | GTX 970 AMP! Extreme Core| 240 GB Kingston HyperX SSD | 2 x 2TB Hitachi HDD | 2 x 2TB seagate HDD | Asus Xonar D2X Soundcard | NZXT 810 Case | Windows 7 Home Premium 64 bit | Dual 27" Monitors
Steam: HackneyHawks
GaryP is offline   Reply With Quote
Old 13th Dec 2016, 15:09   #2
saspro
Infrastructure Specialist
saspro's Avatar
saspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyansaspro is a Super Spamming Saiyan
If you're using MySQL as a backend then you can use PHP for the frontend without rebuilding the backend at all
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is online now   Reply With Quote
Old 13th Dec 2016, 15:12   #3
GaryP
RIP Tel
GaryP's Avatar
Well I have just taken it over and everything is output into asp including all the admin bits. Thats why I assumed it will need to be totally rebuilt. I am completely lost with it.
__________________
Steam: HackneyHawks
Old 13th Dec 2016, 15:35   #4
saspro
saspro's Avatar
MySQL is just a DB, the ASP is the front end that's pulling data. You need a password to get in to MySQL then you should be able pull data out.
A complete rewrite wouldn't be cheap, minimum of 20 hours at £100 an hour or so
__________________
Old 13th Dec 2016, 18:37   #5
deathtaker27
Probook Addict
deathtaker27's Avatar
deathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyandeathtaker27 is a Super Spamming Saiyan
Also please please ensure you cover yourself for SQL Inject and follow OWASP https://www.owasp.org/index.php/Cate...op_Ten_Project
deathtaker27 is offline   Reply With Quote
Old 14th Dec 2016, 01:53   #6
PhoenixTank
From The Ashes
PhoenixTank's Avatar
PhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the Dremel
I've converted a MSSQL & ASP site to MySQL & PHP before - have to admit, not a fun project. We are talking ASP 3/ASP classic, right (.asp)? Not ASP.net (.aspx)? Starting with A MySQL DB might alleviate some of the pain, but I remember the code itself being a real horror. If the site is/was using tables for layout, probably a safe bet that it was built in the same era of web dev.
Any particular reason for wanting to purge ASP? Is your ASP hosting being shut down? Or perhaps because ASP is terrible, and you'd like to make the world a slightly better place? In my case the hosting was getting increasingly less reliable and repeatedly broke as the host upgraded the OS and various bits of the platform. Being realistic, if you have something stable and working, that isn't the worst thing in the world.
That said, if you did want to go ahead... any sort of required timeframe for work on this? Busy time of year. I'm not sure I'd even hazard an estimate without knowing how complex the site and admin area is either. I'll keep an eye on the thread.
__________________
i7 980x stock | Asus Rampage 3 Extreme | Corsair H50 W/ 2x Sharkoon Silent Eagles SE
48GB Corsair Vengeance (3x CMY16GX3M2A1866C9R) | 2x Samsung F3 1TB | 2x Crucial C300 256GB (Boot & Steam)
Asus Mini GTX 960 | HP ZR24w | 32' Samsung B550 | Formac Gallery Xtreme 20.1" MVA
Scythe Kaze Server (fan controller) | Lian Li PC-A77FB | W-75BT Side Panel Window
PhoenixTank is offline   Reply With Quote
Old 1st Jan 2017, 01:53   #7
Evolutionsic
Gives credit where its due
Evolutionsic's Avatar
Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.Evolutionsic is definitely a rep cheat.
Would rebuild the whole thing in Laravel connecting up to the ready made mysql database with migrations.
Easyyy
__________________
Loose lips sink ships
Evolutionsic is offline   Reply With Quote
Old 1st Jan 2017, 02:05   #8
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Originally Posted by Evolutionsic View Post
Easyyy
The famous last words of every programmer ever
theshadow2001 is offline   Reply With Quote
Old 1st Jan 2017, 02:47   #9
Evolutionsic
Iíve seen your magic in that dial java thread, I know when iím beaten!
Bows
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
