Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 3rd Jan 2017, 10:04   #21
mrbungle
Undercooked chicken giver
mrbungle's Avatar
mrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyanmrbungle is a Super Spamming Saiyan
Brake pads on the birds DS3 couple of weekends ago.
Prior to that prob resurrecting some old PC motherboard via recapping.
Actually think it was recapping a Gainward TI4200
__________________
//5930K//Gigabyte X99 SLI//16gb DDR4//Asus 480X Strix 8GB//HX1050w//
mrbungle is offline   Reply With Quote
Old 3rd Jan 2017, 13:22   #22
fuus
Rocking All Year Christmas
fuus's Avatar
fuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyanfuus is a Super Spamming Saiyan
Assorted car electrics in a Golf Estate and a Skoda Octavia
__________________
i5 3570k :: EVGA GTX 670 :: Z77X D3H :: 8GB RAM :: Filco Browns :: 3 x Dell U2312HM :: 256GB 840 Pro
Phillips X1's :: Schiit Vali :: Schiit Modi :: Blue Snowball
fuus is offline   Reply With Quote
Old 3rd Jan 2017, 13:44   #23
Plastic_Manc
Supermodder
Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.Plastic_Manc is definitely a rep cheat.
Fixed the dishwasher a few weeks back as a pipe had come loose so was pumping water into the bottom of it. Refitted the hose and tightened it up and away it went again. Took a beating over the Christmas period so nice to see its held up.
__________________
Fractal Design R4, CM Real Power 850W, Asus Maximus VII Ranger, i7-4790k, 16GB Cosair Vengeance DDR3, Asus Strix GTX 970, Asus PB298Q Ultrawide Monitor@2560x1080, 64GB Crucial C300 and 1TB Samsung F3, Asus Phoebus Solo.
Plastic_Manc is offline   Reply With Quote
Old 3rd Jan 2017, 16:58   #24
asura
jack of all trades
asura's Avatar
asura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyan
In the process of fixing the seal around a friends bath - old silicone's given up the ghost, so it's scrape, scrape, scrape...
I've got some chemical gunk to help dissolve the last annoying little bits which I'm going to give a go on Thursday...
Last thing actually fixed? Oil and filter change and new bulbs for the car would be maintenance... so... it'd be down-lighters in another friends house, some blown transformers some melted chock-blocks due to bulbs with too high a current draw, new transformers, new blocks, new lower wattage bulbs and all's well.
asura is offline   Reply With Quote
Old 3rd Jan 2017, 18:09   #25
Brooxy
Like a boss (but not a boss)
Brooxy's Avatar
Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.
I've fixed / filled a few holes in the wall around the house - it's only taken me 18 months to do that, plus I've fixed the airbag light on the car.
I've also started rebuilding the gearbox on my airsoft AUG - the current gearbox decided to crap out on semi-auto a while back and since taking it apart originally to inspect the (shot) trigger contacts, I noticed a hairline crack in the shell going from the rear of the cylinder, right back to the rear of the shell. Picked up a donor gearbox for a fiver to repurpose the electrics / shell, just need to find the time to finish it, then give it a test where something else will break.
Brooxy is offline   Reply With Quote
Old 4th Jan 2017, 14:46   #26
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
The chain thingy broke at the joint which meant I could not raise and lower my blackout type blinds. A bit of Sugru and we are good to go.
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/256GB Crucial m4/1x1TB & 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is online now   Reply With Quote
Old 4th Jan 2017, 14:48   #27
Kronos
Kronos's Avatar
WD 40 is pretty good at shifting bath sealant.
__________________
Old 4th Jan 2017, 16:57   #28
legoman
breaker of things
legoman's Avatar
legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.legoman is definitely a rep cheat.
Repair list over the last month or two
1930's Irwin No4' metalwork vice (still work in progress)
Wiring for speakers in the car
Mothers computer (more software stupidness like "its in tablet mode!")
New pane and wooden bead trim on one window, seal gone on glaze and part of trim was rotting.
__________________
Taurus excreta cerebrum vincit
Fractual Core 500|Gigabyte GA-F2A88XN-WIFI|Athlon X4 860K|noctua nh-u9s|MSI 480 4Gb|Kingston HyperX Beast 8Gb|Sandisk 240Gb|Crucial BX300 240Gb|Samsung F1 1Tb|
legoman is offline   Reply With Quote
Old 4th Jan 2017, 18:09   #29
asura
jack of all trades
asura's Avatar
Thanks for the tip, I'll give it a go.
Old 14th Jan 2017, 07:50   #30
MeMo
It is what it is
MeMo's Avatar
MeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on you
Repaired a air conditioner and built a dresser, sewing table and coffee table!!! GO me
__________________
"Never find a permanent solution to a temporary problem" "NUFF SAID"
MeMo is offline   Reply With Quote
Old 16th Jan 2017, 00:49   #31
teacherboy
Part Carbon/Nylon/Bovine
teacherboy's Avatar
teacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyanteacherboy is a Super Spamming Saiyan
Broken offside front coil spring on my Saab fixed today along with matching new spring on nearside and fresh drop links- broken springs are a common problem and despite tools, some degree of knowledge and adequate preparation - it still took 5 hours, mostly due to seized bolts and a very silly drop link design that makes them almost impossible to remove.
Have to say having a stupidly powerful impact wrench helped massively (plus a full suite of spanners, jacks etc etc.)
Still - mission accomplished and man level +1
Can add it to list of things on cars that I'm capable of repairing - next weekend will be replacing the exhaust center section as it has a small hole in the flexible part that can't easily/reliably be repaired any other way than replacement of the whole piece.
__________________
Planning more charity bike rides but building a road bike first.......
teacherboy is offline   Reply With Quote
Old 16th Jan 2017, 04:39   #32
MeMo
It is what it is
MeMo's Avatar
Good Job!!!
__________________
Old 16th Jan 2017, 04:46   #33
MeMo
It is what it is
MeMo's Avatar
Installed a new key board on my laptop.
__________________
Old 16th Jan 2017, 05:18   #34
BentAnat
Software Dev
BentAnat's Avatar
BentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for president
Weeeelll... maybe not FIXED per se, but:
Took the old pickups out of my guitar, only to realise there was a cabling fault for the past 10 years.
So I fixed that (so I suppose "fixed" is right) and installed new, better pickups.
__________________
Find Jobs in Namibia
BentAnat is offline   Reply With Quote
Old 16th Jan 2017, 11:01   #35
blackerthanblack
Supermodder
blackerthanblack's Avatar
blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.blackerthanblack is definitely a rep cheat.
Fixed my daughters' Nintendo 3DS XL after she dropped it and broke the top screen. Didn't realise you have to pretty much take it all to bits to get it changed, so took a lot longer than I thought. I also broke one of the tiny ribbon cable clips so it took me two attempts to patch something together so it works
__________________
There is so a spoon
blackerthanblack is offline   Reply With Quote
Old 16th Jan 2017, 11:48   #36
Pliqu3011
The cake is an alternative fact
Pliqu3011's Avatar
Pliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming Saiyan
- Installed a diode in a Gossen Lunasix lightmeter to use modern 1.5V batteries instead of the 1.3V mercury ones you can't get anymore.
- "Fixed" the broken advance lever of a €0.50 Yashica FX-D with a dab of JB Weld. Don't know if it will hold in the long term but it seems sturdy enough.
This I didn't manage to fix:
- I had to completely disassemble a Thinkpad T510 (even remove the CPU cooler) to get access to the motherboard where I was 99% sure a faulty diode was the cause of the failing LCD backlight, only to find out all video related diodes work perfectly (according to my multimeter). The only other cause I can think of is a broken LCD cable, though it looks fine tbh.
Luckily I managed to not destroy anything during the disassembly and reassembly.
I now ordered a new LCD cable, so in a few weeks I'll have to take it apart all over again...
__________________
“Talent is a pursued interest. In other words, anything that you're willing to practice, you can do.” - Bob Ross
“Ὁ βίος βραχύς, ἡ δὲ τέχνη μακρή, ὁ δὲ καιρὸς ὀξύς, ἡ δὲ πεῖρα σφαλερή, ἡ δὲ κρίσις χαλεπή.” - Hippocrates
Pliqu3011 is offline   Reply With Quote
Old 16th Jan 2017, 12:19   #37
legoman
breaker of things
legoman's Avatar
Not done my links are yet but they usually put a pair of notches on the rubber boot side to take a spanner which helps.
I "repaired" the audio in my saab, couple years back the pollen filter clogged an filled the passenger footwell with water, water went under the passenger seat where the cars amp lived. Amplifiers are not aquatic by nature so it promptly died. Saab wanted £400 for the part plus fitting which entailed a plug and a screw.
So, I bought an amp headunit an cables ages ago for less than £400, headunits been in working for a while now, just the amp end took longer an I did it at the weekend.
New aftermarket amp in the boot, power cable ran from the battery under the bonnet and earth line from within the boot. Door speakers used a connector from the old amp under the passenger seat which I butchered an added my own connectors. Speaker cables been ran from under the passenger seat to the boot. I only tested it so ended up draping the remote and RCAs over the seats not fitting them. But it works I'm calling it repaired but not finished but it works
So basically I bypassed the amp all together I have a working aftermarket headunit and amp and the dealer said it wouldn't work due to fibreoptics, I beat the fibreoptics using a plastic tube from a small paint brush
__________________
Old 17th Jan 2017, 00:59   #38
teacherboy
teacherboy's Avatar
This I was aware of but when the bolt is pretty much rusted in place and the notch is only made of soft-ish alloy it rounds off pretty quickly - my advice is get some penetrating fluid on there ahead of time, go away for an evening and then tackle the job the next morning when you stand a better chance - either that or a really good set of hardened jaw mole grips to grip the backside of the drop link when the notch inevitable rounds off
I put these on mine in case you wanted a tip for stronger, uprated parts when you come to do it - added bonus is higher strength alloys to stop the notch rounding - making them easier to get off if needed!
__________________
Old 17th Jan 2017, 08:03   #39
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.
at work:
3x Lenovo X230's
2x Lenovo x1 Carbon Gen1's
3x Lenovo X1 Carbon Gen2's
2x Lenovo X1 Carbon Gen3's
All leavers laptops with hardware faults or broken plastics.
At home:
Had to replace the entire Drivers side rear light cluster on my 1 Series as Tuesday last week some asshole decided it would be fun to smash it for me.
__________________
Originally Posted by GreatOldOne View Post
That just made me LOL my coffee over my keyboard....
Intel i7 2600k | Be Quiet Dark Rock Advanced | ASUS P8P67 pro | Patriot 1600 6GB | XFX 6870 Twin fan | corsair 650W | OCZ Vertex II 30gb | Samsung SP 1TB, Samsung 1.5TB, Samsung 500GB | Lian Li V-1000 | 2x23" screens
crazyg1zm0 is offline   Reply With Quote
Old 14th Feb 2017, 17:12   #40
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Just fixed our microwave, the start button had broken, I just needed to solder a new switch onto the pcb.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
