Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 11th Jan 2017, 10:33   #1
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Can I stop Windows 10 changing my desktop?
So the other day whilst Arbro was here I fired up my Titan X rig to show him something. It copied my desktop from another rig, leading to serious confusion on my part.
Can I stop Windows doing this? I want different backgrounds on each rig so I know where I'm at.
NVM seem to have found it
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 11th Jan 2017, 11:55   #2
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Settings > Accounts > Sync your settings > Turn theme off (both PCs)
I think that should work.
Edit: Yup, I didn't read the I did it part
noizdaemon666 is offline   Reply With Quote
Reply
Tags
d'oh
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
