Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 31st Jan 2017, 09:29   #1
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
DIY Help: Cat Shelves.
I have a mattress standing waiting council collection on Thursday which is currently in my living room which my cat Millie thinks is a fantastic place to lie and watch the world go by. So I thought I might put up a shelf for her to lie on and a a couple of others to enable her to reach it.
Pretty much got all the components, nice bit of MDF, some carpet underlay and stuff I can use for a covering. What I don't have and the reason for the thread is brackets.
Ideally I would like them to be hidden as in Amazon but I am concerned by A) will they hold the weight of a 5Kg cat laying on a MDF shelf around 70cm long x 28cm wide and thickness is only 18mm. The shelves to give her access (2) would not be as big of course but might need to take her weight on her way down.
Or is there some other neat way of supporting the main shelf?
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/500Gb OCZ TR150 SSD/2 x 25Gb SSD/ 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is online now   Reply With Quote
Old 31st Jan 2017, 10:11   #2
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
A floating shelf bracket looks like it should do the job. Is it going into woodwork, masonry or plaster board?
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is offline   Reply With Quote
Old 31st Jan 2017, 10:17   #3
Kronos
Kronos's Avatar
Actually got them, but the next size up, in my basket on Amazon but I am not happy with A) the length as I would have preferred them to have gone a little deeper into the shelf and B) drilling a 14mm hole will only leave 2mm top and bottom of bracket which seems a bit less than I would be comfortable with.
__________________
Old 31st Jan 2017, 11:04   #4
crazyg1zm0
Mod Master
crazyg1zm0's Avatar
crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.crazyg1zm0 is the Cheesecake. Relix smiles down upon them.
I have done a few, Using Ikea floating shelves. I have used anchor bolts that will support upto 10kg on plasterboard to be sure. and its working perfectly.
The bolts i Got from B&Q and work like a treat.
__________________
Originally Posted by GreatOldOne View Post
That just made me LOL my coffee over my keyboard....
Intel i7 2600k | Be Quiet Dark Rock Advanced | ASUS P8P67 pro | Patriot 1600 6GB | XFX 6870 Twin fan | corsair 650W | OCZ Vertex II 30gb | Samsung SP 1TB, Samsung 1.5TB, Samsung 500GB | Lian Li V-1000 | 2x23" screens
crazyg1zm0 is offline   Reply With Quote
Old 31st Jan 2017, 11:13   #5
Kronos
Kronos's Avatar
As I have said I have pretty much got all I need to make these things up so not really looking to go to the expense of buying shelving. I think I have got around the lack of thickness on top and bottom of brackets by adding a layer of hardboard on the top and bottom of the MDF, gluing and stapling it which has added a bit more thickness and of course more strength. Just in the process of covering the main shelf hoping I have enough decorative upholstery nails left I bought recently for another project.
__________________
Old 31st Jan 2017, 11:36   #6
B1GBUD
B1GBUD's Avatar
Could you not get a cheap off-cut of 25mm? Wickes, B&Q or Homebase might have some going begging if you ask nicely.
__________________
Old 31st Jan 2017, 11:40   #7
Kronos
Kronos's Avatar
Thought about that but as I don't have the transport and these places are all a fair bit from me it was not viable. I think the hardboard lining top and bottom should be OK.
__________________
Old 4th Feb 2017, 03:02   #8
SMIFFYDUDE
Supermodders on my D
SMIFFYDUDE's Avatar
SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.SMIFFYDUDE is definitely a rep cheat.
Have you thought about a cat hammock you hang on a radiator? Our cat loves hers.
__________________
i7 6700K|Sabertooth Z170 S|16GB Crosair Dominator Platinum 3200MHz|KFA2 GTX 1080 HOF|Creative Sound Blaster ZxR|Super Flower Leadex Gold 850W|Corsair 780T|HP LP2475w|Speedlink Medusa 5.1|CM Storm Inferno|Windows 10
Steam: SMIFFY
SMIFFYDUDE is offline   Reply With Quote
Old 4th Feb 2017, 05:29   #9
Kronos
Kronos's Avatar
She is not a radiator type of cat, perhaps this is because she has a very thick coat so not keen on the beat from one. Plus the shelves are more if a height thing, well the top one anyway, as she does tend to enjoy looking down on her servants.
__________________
Old 7th Feb 2017, 13:44   #10
Kronos
Kronos's Avatar
After trying to drill 3 straight holes 14mm x 165mm long in the edge of a 120mm board and failing miserably I have just bought two sheets of MDF which I will glue and screw giving me a far thicker edge to deal with. Plus I have bought myself something I have been promising myself for years a Black&Decker workbench I will hopefully make a better job of the hole drilling.
__________________
Old 2nd Mar 2017, 15:42   #11
Kronos
Kronos's Avatar
After a bit of a delay they are finished though as yet have not been graced by Millie.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
