Reply
Thread Tools View Mode
Old 12th Mar 2017, 16:38   #41
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Good idea to put the blocks in contact with the heat sink. Anchor them to it, so the weight doesn't hang off the motherboard and GPU.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 14th Mar 2017, 20:52   #42
Bennibo
Modder
Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.Bennibo is the Cheesecake. Relix smiles down upon them.
thanks
i continued on that little stuff inside.
- tapped a few threats for the LED mounts, so everything stays in place now.
- worked on the mounts for the SSDs. Theres room for up to 6x 2,5" drives now.
- put the power button in the buttom. unfortunately i made the hole a little too big....
- started on the mount for the front USB ports, which is not done yet.
__________________
completed project: Black Silence HTPC
recent project: no name yet
Bennibo is offline   Reply With Quote
Old 14th Mar 2017, 22:55   #43
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
I like the concealed power switch. That would really help in my house with little fingers that love to push buttons.
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 15th Mar 2017, 10:19   #44
Taugeshtu
What's a Dremel?
Taugeshtu's Avatar
Taugeshtu has yet to learn the way of the Dremel
Bennibo, this build is very exciting! I have a soft spot for passive builds (in fact, planning one of my own).
Have you seen this case? Just to give you some sort of encouragement: its rads surface area is about 6000 cm^2, give or take couple hundreds, and your rad is around 11000 cm^2.
Using math magic from here Airtop arrives at about 100 m^3/h of airflow in each channel; yours should be around the same (emphasis on "should"). All of that with nice and warm 30 C outside temperature and 70 C on the radiator (with components sitting at nice toasty 80 C due to heat transfer and all that). And linked above case dissipates 200 Watts!
I think (but don't know for certain) that the stack effect just might get you covered even without fans under load So, cheers and have a happy build, it's very inspiring!
Taugeshtu is offline   Reply With Quote
Old 15th Mar 2017, 16:02   #45
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Hole too big: It happens. Fortunately, you can fill the gap with grey epoxy and no one will ever see it.
You can even make the hole a little bigger, fill it, sand it flat, and grind a new hole in the center. The ring around the switch would look deliberate then.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 17th Mar 2017, 13:31   #46
Dot_Kappa
100% Puppet
Dot_Kappa's Avatar
Dot_Kappa has yet to learn the way of the Dremel
The top is fantastic !!
The render doesn't make me crazy but looking at the final pics I admit I was wrong
Dot_Kappa is offline   Reply With Quote
Old 17th Mar 2017, 19:00   #47
Bennibo
Modder
yes, definitely and because the case is up on that feet you can still easily puch that button.
thanks! i saw that system when it was first released. I did my calculations and i think i should be alright, but in the end we will see how my system performs and if everything was correct
thanks, thats a good idea!
thank you!
i soldered a few things and got the lighting in the buttom done. I tried to hide the cables as good as possible.
__________________
Old 18th Mar 2017, 09:43   #48
ADmodz
Modder
ADmodz has yet to learn the way of the Dremel
Fantastic work dude
ADmodz is offline   Reply With Quote
Old 21st Mar 2017, 21:09   #49
Bennibo
Modder
thank you!
i finished work on those front USB-ports. maybe except for straightening them out.
__________________
Old 21st Mar 2017, 22:47   #50
LennyRhys
Fan Fan
LennyRhys's Avatar
LennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming Saiyan
This is seriously cool.
__________________
i7 5820K | MSI X99A Gaming 7 | 32GB Ballistix Sport | EVGA GTX980Ti SC | Corsair RM550 | Dell U3014
LennyRhys is offline   Reply With Quote
Old 22nd Mar 2017, 14:29   #51
mal
Modder
mal's Avatar
mal has yet to learn the way of the Dremel
Are you going to paint it black as well? If so call it "Monolith". They are smooth sided, silent, towers. Or "Obelisk".
mal is offline   Reply With Quote
Old 22nd Mar 2017, 15:45   #52
Cheapskate
Cheapskate's Avatar
I think the 'monolith' refers to that monster inside.
__________________
Old 22nd Mar 2017, 15:55   #53
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Nice one man. I'm trying to get my head around the actual scale of it atm. It looks positively tiny, but standing on that work bench my brain is telling me it's actually bigger than it looks.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 22nd Mar 2017, 19:18   #54
Dr. Coin
Supermodder
Dr. Coin's Avatar
Small..
Originally Posted by Bennibo View Post
Big...
well bigger at least.
__________________
Old 22nd Mar 2017, 19:42   #55
Bennibo
Modder
thanks guys!
I will have it anodized in black, just like my little HTPC.
I actually like monolith. Thank you! Obelisk has a pyramid on top, that doesnt really fit.
The case is 155x340x400mm (with feet). The cutouts in the top are for 140mm fans.
To give you an idea i took some pics right next to my Lianli A71 and with a 120mm fan, a beer and a 1,5liter bottle, i hope that helps
on the left is the heatsink that is going in there, which takes up (84mm) more than half of the total width of the case.
__________________
Old 23rd Mar 2017, 08:09   #56
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
having a look at the size of the case, with the heatsink on the side, really shows what this build is all about! - that sink is absolutely massive looking, compared to the case.
i haven't been this excited for a build in a very long time, and am really looking forward to you getting started on hooking your hardware up with cooling components.
__________________
storm-83 is offline   Reply With Quote
Old 23rd Mar 2017, 14:33   #57
mal
Modder
mal's Avatar
thanks guys!
Glad I could help.
Old 23rd Mar 2017, 14:36   #58
LennyRhys
Fan Fan
LennyRhys's Avatar
Looks awesome. That Lian Li case could pass as a fridge... it's frickin' enormous.
__________________
Old 23rd Mar 2017, 20:05   #59
Bennibo
Modder
Its not that big. Its only slightly bigger than a more modern BeQuiet 900.
There is internal watercooling inside, so having some room is not a bad idea
yes, the heatsink is definitely the centerpiece of the case.
I am excited as well. I still dont have any hardware that is going to go in there. The PC im using right now is an ATX size one (inside the LianLi), so i need to get a new PSU and mainboard, including RAM, CPU.
Right now, im thinking about an Intel platform with an 7700K or 7600K.
Im still not sure about the graphics card. I want to use a 1080, just because i wanted to build a highend, silent and compact gaming PC, but i hardly ever play games anymore and im not sure, if i want to spend so much money...
If i cant find a sponsor , i might use my 970 instead. It has about the same power consumption, so i can still have my cooling system proven.
__________________
Old 29th Mar 2017, 20:03   #60
Bennibo
Modder
just a small update today.
i countersunk the holes in the aluminum panels (except for the one in the top, but i will get that done later ) and tapped threats to hold the farbwerk in place up front. I still need some spacers for that.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
