Old 5th Feb 2017, 06:05   #1
thechoozen
Hypermodder
thechoozen's Avatar
thechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysisthechoozen can run Crysis
Julias Madness
Time for a new Project
It´s based on a CM Mastercase and it will be built for our little Sister.
She was in need of a new System and her last mod [roku] is also several years old so we decided that the time has come for something new.
And after a few discussions with her, we finally found a theme for this build; which is Alice in Wonderland / Alice Madness.
So, this time it starts with a grin.....
to be continued....
thechoozen is offline   Reply With Quote
Old 5th Feb 2017, 06:15   #2
MeMo
It is what it is
MeMo's Avatar
MeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on youMeMo - may the hammer of Bindi be bestowed on you
OMG I Love it!!!!!! So much that I want one!!! I will be watching this one closely.
__________________
"Never find a permanent solution to a temporary problem" "NUFF SAID"
MeMo is offline   Reply With Quote
Old 5th Feb 2017, 10:33   #3
GorgTech
Minimodder
GorgTech has yet to learn the way of the Dremel
I hope that you are going to paint that thing Pink color is quite aggressive to the eyes. I love the 3D printed parts though.
GorgTech is online now   Reply With Quote
Old 5th Feb 2017, 14:05   #4
Dot_Kappa
100% Puppet
Dot_Kappa's Avatar
Dot_Kappa has yet to learn the way of the Dremel
Chesire Cat
I love it !
Did you use Uv-paint ?
Dot_Kappa is offline   Reply With Quote
Old 5th Feb 2017, 14:13   #5
davido_labido
Staff
bit-tech Staff
davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.
cant wait to see what you do with this you sexy German babes!
davido_labido is offline   Reply With Quote
Old 5th Feb 2017, 17:15   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
You can print German babes now? -I might need to shop for a printer. Viva technology!
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 6th Feb 2017, 18:56   #7
thechoozen
Hypermodder
thechoozen's Avatar
Lol Ty m8s!!!!
i can totally understand that, that model of the cheshire cat really rocks! (you can find it on thingiverse) but its also just an add on for the case.....
ty!!! and sure it will be painted....but i have to disappoint you...because it will be painted in pink and purple
Chesire Cat
I love it !
ty!!! and yes this time we use special UV-Paint so that the Colors react on UV-Light ... for that special effect on that special cat....
ah Dave my sexy Bear is stepping in with his raw masculinity.....
it´s always some kind of soap dropping moment.....
that would be a really nice feature...but can´t find a resin which can do a decent nagging....
Old 8th Feb 2017, 18:33   #8
thechoozen
Hypermodder
thechoozen's Avatar
Soooo, it´s time for the first Update:
As next we printed a cover for the I/O Ports of the Mainboard that we´re going to use in this build.....
We also printed and painted a few smaller parts which we want to integrate in the mod.....
and for sure, we finished the cheshire cat....
Old 8th Feb 2017, 20:20   #9
Cheapskate
Cheapskate's Avatar
NO! He's not done. That smile needs touched up in glow-in-the-dark paint.
__________________
Old 12th Feb 2017, 17:55   #10
thechoozen
Hypermodder
thechoozen's Avatar
sorry i should have written done for the moment
As next we disassembled the Graphic Card Cooler so that we could paint the Fan cover and Fan blades....and we also overworked the radiator for the WC loop.....
As next we´re going to switch over to the case itself and start the cutting process for the window in the sidepanel....
Old 19th Feb 2017, 18:05   #11
thechoozen
Hypermodder
thechoozen's Avatar
As announced, we continued our work with the sidepanel. So we first took the sidepanel of and made a quick pencil drawing on it....just to discuss the exact position & shape of the window....
.....after that we could print out a piece of fence which we will mount on the sidepanel to give the complete mod a bit more structure....
And then we started the cutting process on the sidepanel....
And we overworked the mounting bracket for the CPU Cooler so that it matches the overall "wood" theme of the mod.....
Old 19th Feb 2017, 20:31   #12
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Awesome
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 24th Feb 2017, 04:55   #13
thechoozen
Hypermodder
thechoozen's Avatar
Thank you!!
Time for the next Update:
After finishing the cutting process of the window....we directly started to add some structure to some parts of the sidepanel...so that we could start the painting process afterwards....
Beside that we already mounted the I/O Shield and the CPU Block for the first time....just to see how it will look like....
We also overworked the paint on the radiator a little bit, so that the wood grain gets darker then before and we also prepared the Fans for the Radiator & Case for a fresh coat of paint....
Old 24th Feb 2017, 05:42   #14
MeMo
It is what it is
MeMo's Avatar
Sooooo Awesome!!
__________________
Old 8th Mar 2017, 04:10   #15
thechoozen
Hypermodder
thechoozen's Avatar
thank you!!
As next we prepared the next pieces for the Front and the 2nd sidepanel.....
beside that we continued the work on the outside a little bit
and we also started to add some paint to the inside of the case....so it will blend in with the paint on the sidepanel....
Old 17th Mar 2017, 18:41   #16
thechoozen
Hypermodder
thechoozen's Avatar
In the last days we continued our work on this mod first we put some paint on the Mad Hatter for the 2nd sidepanel....
Beside that we also start the airbrushing process on the 2nd sidepanel...so that we could add our printed mad hatter to the panel afterwards....
we also added some more details to the Frontpanel
And we already started to mount the hardware for a first test....
Old 18th Mar 2017, 06:57   #17
MeMo
It is what it is
MeMo's Avatar
So cool!! I am exited to see the end result!!
__________________
Old Yesterday, 17:57   #18
thechoozen
Hypermodder
thechoozen's Avatar
thank you! and you don´t have to wait that long....only until tomorrow....
As next we added some last details to the Front Panel, after that we also mounted the prepared door knob...so that the front panel is nearly finished....
Then we build a custom reservoir which we could mount under the Top of the Case....
After finishing the reservoir...we directly mounted it inside the case so that we could start bending the rigid tubing and add some water....
And last but not least we mounted the mad hatter & the piece of fence on our sidepanels....
Old 26th Mar 2017, 19:04   #19
thechoozen
Hypermodder
thechoozen's Avatar
And here are some final pics:
Old 26th Mar 2017, 20:04   #20
MeMo
It is what it is
MeMo's Avatar
This is truly the coolest project I have ever seen! A+++++ all the way!!!!clap::
__________________
Reply
Tags
alice madness, alphacool, babetech.de, bt-custompc.de, klevv
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
