Reply
Thread Tools View Mode
Old 1st Mar 2017, 16:54   #21
MPC
Multimodder
MPC's Avatar
MPC has yet to learn the way of the Dremel
Create aluminum profiles for supporting the structure of the base, and finally begins of the various CNC cuts.
MPC is offline   Reply With Quote
Old 8th Mar 2017, 13:24   #22
MPC
Multimodder
MPC's Avatar
Custom realisation of fastening profiles for some of the base plates inclined to 30 °.
Old 8th Mar 2017, 15:40   #23
hayate89
What's a Dremel?
hayate89 has yet to learn the way of the Dremel
overkill
hayate89 is offline   Reply With Quote
Old 8th Mar 2017, 17:08   #24
MPC
Multimodder
MPC's Avatar
ahahah yes
You might be right but I really like the things resistant
Old 13th Mar 2017, 13:18   #25
MPC
Multimodder
MPC's Avatar
Structure of aluminum profiles complete.
Old 13th Mar 2017, 15:51   #26
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
That's a lot of frame. It's so mechanical, I'd be afraid to put my fingers near it.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 13th Mar 2017, 17:25   #27
MPC
Multimodder
MPC's Avatar
I am determined to realize the very strong structures and this is one example
Old 17th Mar 2017, 17:27   #28
MPC
Multimodder
MPC's Avatar
Realization of the side panels of the base with perforated grid for a better airflow.
Old 18th Mar 2017, 18:15   #29
MPC
Multimodder
MPC's Avatar
Bonding of the various mahogany wood panels.
Old 18th Mar 2017, 19:19   #30
ADmodz
Modder
ADmodz has yet to learn the way of the Dremel
Fantastic work dude
ADmodz is offline   Reply With Quote
Old 18th Mar 2017, 19:21   #31
MPC
Multimodder
MPC's Avatar
Originally Posted by ADmodz View Post
Fantastic work dude
Thank you Admodz
Old 20th Mar 2017, 18:33   #32
MPC
Multimodder
MPC's Avatar
Hand folding of the base structure, for get a better look, finally painted with ivory color.
Old 23rd Mar 2017, 13:58   #33
MPC
Multimodder
MPC's Avatar
Terminal caps of the 8 tubes. Cutting of aluminum bar, finally I use the lathe and open a thread hole.
Old 24th Mar 2017, 15:38   #34
MPC
Multimodder
MPC's Avatar
Aesthetic ferrules positioned around 8 tubes and anchored on the wood texture. internal and external mirrored cut.
Old 24th Mar 2017, 16:24   #35
Cheapskate
Cheapskate's Avatar
machine shop porn is always welcome.
__________________
Old 24th Mar 2017, 17:02   #36
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
Looks good!!
GravitySmacked is offline   Reply With Quote
Old 25th Mar 2017, 00:24   #37
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
Interesting. I want to see more.
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is online now   Reply With Quote
Old 25th Mar 2017, 10:16   #38
MPC
Multimodder
MPC's Avatar
It's true. I love the charm of industrial machinery and their work
Originally Posted by GravitySmacked View Post
Looks good!!
Thank you Gravity
Thanks Coin, soon there will be the next step
Old 25th Mar 2017, 15:32   #39
MPC
Multimodder
MPC's Avatar
Terminated the terminals caps. It's visible the contrast between gold and silver after the one between clock gears and relative pins with plates.
Old 28th Mar 2017, 11:05   #40
MPC
Multimodder
MPC's Avatar
Clock Hands in 1.5 mm thick aluminum. They will also be anodized , but with a special color...different from the gold or silver.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
