Reply
Thread Tools View Mode
Old 11th Mar 2017, 21:53   #21
CroyAlore
Minimodder
CroyAlore's Avatar
CroyAlore has yet to learn the way of the Dremel
Originally Posted by Vault-Tec View Post
I would love to see that yes
Here is the original model with no cutout's (My friend made all of these designs for me), I was thinking of leaving the front like this:
I then decided to have the fans show so to begin with I had the front open:
Then I added the design to the front (Final Design):
Lots of things in PC modding are over done. Whenever a new idea or part comes along every one rushes to use it. It's not that I don't like hard tubing at all, it's just that I have seen so much of it I just get tired of seeing the same thing. It's kinda like Caselabs syndrome. At first I loved the elegance and quality, and then I just got sick of seeing it.
So I'm glad you chose to use flexible tubing. In the right hands it can look every bit as good, if not better, than hard tubing.
It's far better to use your own mind and your own ideas rather than those of others when modding IMO.
Yeah I completely understand, I've noticed this same trend. It would nice if there were more than just the two options when it comes to building a loop, but I guess that just means we got to start coming up with creative ways of using one or even both styles in a build. And the same thing goes with the way we go about modding our cases.
I've seen some builds do really well with the hard tubing, and some do amazing with flexible, but the problem I've seen is that sometimes the build doesn't use the style that fits it.
I'm glad you prefer the flexible tubing in this build, it took a while for me to decide what parts of the loop would be the acrylic tubing, and what parts would stick to the flexible tubing.
__________________
CroyAlore is offline   Reply With Quote
Old 11th Mar 2017, 21:56   #22
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Yeah you definitely chose the right design
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 18th Mar 2017, 13:20   #23
kim
Multimodder
kim has yet to learn the way of the Dremel
about new trends...I am generally not a fan of this rainbow RGB lighting effect, but it's the third time that I follow your thread and I must say that it looks pretty nice in your particular build, besides I love your front design grill and your case is really beautifull... also impressed by the extreme neatness of your work and pictures...
kim is offline   Reply With Quote
Old 19th Mar 2017, 08:20   #24
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks kim for the very kind words
I'm very picky about details so a scratch build was perfect for me, and I tried to ensure all the details of this build were clean and organized. I was originally going to set all the led's to white but the colors ended up working well with the case.
__________________
Old 19th Mar 2017, 11:19   #25
Maarten/Pine
What's a Dremel?
Maarten/Pine has yet to learn the way of the Dremel
That are some nice modding skills man! I like how you used the aluminium, really clean-looking.
Maarten/Pine is offline   Reply With Quote
Old 19th Mar 2017, 17:58   #26
Cleveland216
Carbon Fiber King
Cleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the DremelCleveland216 has yet to learn the way of the Dremel
What CAD program are you using?
Cleveland216 is offline   Reply With Quote
Old 20th Mar 2017, 01:51   #27
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks Maarten/Pine, I love using aluminium its very easy to work with.
The models where made by a friend using SolidWorks
__________________
Old 22nd Mar 2017, 04:20   #28
CroyAlore
Minimodder
CroyAlore's Avatar
Hey all, I got some more photos of the Led's for now until I figure out a way to mount the SSD/HDD's
Here they are (Caution for anyone sensitive to moving colors/lights):
Gif of the LED's
__________________
Old 31st Mar 2017, 05:28   #29
CroyAlore
Minimodder
CroyAlore's Avatar
I got a quick update, Here is some of the last components to go in the case that I just finished sleeving.
Had to sleeve these cables and replace the red connector with a white one to match the case better.
Internal USB Hub to help manage the aquaero components as well as the Hue+ Hub.
__________________
Old 31st Mar 2017, 08:03   #30
kim
Multimodder
perfect sleeving...and pics
Old 31st Mar 2017, 15:24   #31
FatalSyntaxError
Minimodder
FatalSyntaxError's Avatar
FatalSyntaxError has yet to learn the way of the Dremel
Looking really nice! Ever since I got my Ncase M1 I've had a thing for small and space efficient build!
Just out of curiosity why didn't you just have the back panel be apart of the front unibody design and just bend it at the top so it comes down then screw it in place at the base like you've done already?
__________________
All edits are for speling spelling and grammar unless otherwise stated
FatalSyntaxError is offline   Reply With Quote
Old 9th Apr 2017, 09:12   #32
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks kim
Thanks FatalSyntaxError
I really like efficient builds, after looking at a lot of cases I decided that the only way I would be able to get a case that is as small and efficient as I needed was to just build my own.
I wanted the back panel to be separate from the uni-body because I like the look of a separate back panel and allowed me to use a thinner metal for it making it distinctly different than the uni-body. This also allows for easier future modifications and color changes if needed.
__________________
Old 3rd May 2017, 07:40   #33
CroyAlore
Minimodder
CroyAlore's Avatar
Hello all, I have finally completed the project, here are the final photos:
__________________
Old 4th May 2017, 22:26   #34
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
Very clean build- super simple- love it love it
hairyknacker is offline   Reply With Quote
Old 12th May 2017, 00:44   #35
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks! I'm glad you like it, I may be posted some more photos later with different color schemes.
__________________
Old 12th May 2017, 08:14   #36
kim
Multimodder
awesome, awesome, I love it....and your pics are...soooo perfect, hope to see you building again soon
Old 21st May 2017, 03:32   #37
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks for the kind words, I am in the planning phase of the next build, which will be much smaller than this one size wise, hopefully you'll like it as much as this one
__________________
Old 22nd May 2017, 00:17   #38
Andreas | Brodholm
Multimodder
Andreas | Brodholm's Avatar
Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!Andreas | Brodholm - it's over 9000!!!!!!!!1!1!1!!!
Beautiful! 5 out of 5 stars.
you made something great. The RGB-table plate really brings the whole build together. Great work!
__________________
[Scratchbuild]
Water Cooled Chassis built from scratch!
Have a look and let me know what you think!
Completed! (Pictures Inside)
Andreas | Brodholm is offline   Reply With Quote
Old Today, 03:58   #39
CroyAlore
Minimodder
CroyAlore's Avatar
Thanks Brodholm, really appreciate the kind words.
Btw, cant wait to see how your build completed, great job so far you've really raised the bar
__________________
Reply
Tags
custom case, scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
