Old 20th Feb 2017, 18:27   #1
warboy
Insane modder
warboy's Avatar
warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.
FENWAR
Hi! guys!
I start work at another mod starting from the Case Bitfenix Shogun
I want to change the design and colors of this fantastic case
POWER SUPPLY: FSP HYDRO G 750W
Motherboard:
MSI Z97A GAMING 6
Graphics Card:MSI GTX 980 GAMING 4G
Case: BitFenix Shogun
Ram: 16 Gb CORSAIR VENGEANCE(4x4Gb)
Fans: 6 x Bitfenix Xtreme Spectre Pro LED blue
LED: Alchemy 2.0 Magnetics Led Strips RGB controller 150 cm
CPU: Intel i7 4790k
SSD: Samsung PRO 128 GB
HDD: 4 TB WD Green (2 x 2Tb)
Now some hardware photos
The power Supply is FSP HYDRO G 750W
warboy is offline   Reply With Quote
Old 21st Feb 2017, 18:00   #2
warboy
Insane modder
warboy's Avatar
Old 21st Feb 2017, 18:07   #3
warboy
Insane modder
warboy's Avatar
and now the fans!
BITFENIX SPECTRE XTREME LED BLUE
Old 26th Feb 2017, 12:31   #4
warboy
Insane modder
warboy's Avatar
The lighting of the case will be entrusted to the BitFenix Magnetic RGB LED controller may change due to their effects and lights.
Although the c BitaseFenix Shogun already has a controller for the LEDs.
And then some of sleeving with BitFenix Alchemy 2.0 sleeved Cable
Old 26th Feb 2017, 20:12   #5
warboy
Insane modder
warboy's Avatar
I usually start with a mod when I start with a well-defined project and then add details and changes during construction.
As in this case that with a simple modification to the case, I repositioned the power buttons, reset and USB ports from the front to the rear.
Here is an overview of the case:
These are the supports for the GPU
Take down some of parts
Old 6th Mar 2017, 20:14   #6
warboy
Insane modder
warboy's Avatar
Now i customize the power supply:
un FSP Hydro G 750
I painted some details with the airbrush with acrylic paint water-based
Old 8th Mar 2017, 20:46   #7
warboy
Insane modder
warboy's Avatar
After the power supply starts to place the radiator 360mm, with 3 fans Spectre Xtreme LED BLU that will be linked to the BitFenix Recon for the speed and temperature management)
And with a bit of plexiglass cuts begin to customize the exterior of the case
Old 17th Mar 2017, 18:51   #8
warboy
Insane modder
warboy's Avatar
After i painting the parts plexy and...
Now start with mounting
Old 18th Mar 2017, 17:34   #9
warboy
Insane modder
warboy's Avatar
For the liquid cooling system i use
PUMP AND RESERVOIR: EK XRES 100 D5 vario†
WATERBLOCK: Alphacool NexXxoS XP≥ Light - Acetal Edition†
RADIATOR: Alphacool NexXxoS ST30 Full Copper 360mm†
Old 18th Mar 2017, 18:01   #10
warboy
Insane modder
warboy's Avatar
Old 21st Mar 2017, 18:03   #11
warboy
Insane modder
warboy's Avatar
Old 21st Mar 2017, 18:06   #12
warboy
Insane modder
warboy's Avatar
and with special guest DanielaCordella
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
