Reply
Thread Tools View Mode
Old 21st Feb 2017, 23:10   #1
Huskybongs
What's a Dremel?
Huskybongs has yet to learn the way of the Dremel
Magogany/steel Pc deskli
Hello,
I've been building this a while but wasn't confident enough to put it up on these forums before now.
The idea is to take that grand piano feeling to a pc. We'll be using fairly nice materials for this such as teak, mahogany, oxygen resistans steel and a lot of chromed parts. The build has been in the works for about 2 years with an estimated finish this spring. (currently doing bespoke cables). With that being said let's go over the parts and into the actual buildlog.
A massive shoutout to Mikael who's helped me with a lot of the woodwork. This build would not have been possible without your help
PC parts:
Motherboard: MSI BigBang Xpower 2, x 79 lga 2011¨
CPU: Intel i7-3930k @ 4.6Ghz
RAM: 32GB Corsair Dominator 1866Mhz
PSU: Corsair ax1500i
GPU(s): 2xGTX 980s overclocked to whatever I can reach
HDD/SSD: 2xWD red 6tb+3xV-Samsung 500gb. 2 in raid and 1 as bootdrive
Watercooling:
Radiators: 2xmonstah 560mm,1xalphacool 360mm
Pumps: Plexitop EKWB d5x2
Piping: Iodized copper
Reservoir: Custom Singularity Dual loop acrylic reservoir.
Fans: Various Noiseblocker fans 25 in total.
Sponsors:
Lets start off then.
Solid drawing
Let's weld. Starting off with the basic shape. Table will be roughly 1800x780mm
Radiator bay:
Parts started to come in
After a few more hours I have room for my legs and some placement for the fans
http://i.imgur.com/UKIGtMkl.jpg
Space for knees
Gonna want some monitoring
The wood was ordered like this. Huge chunks of birch. The will be shaped to be the outer panels of the chassi. It's a really dense wood and it's been dried for years properly before being used.
Quite heavy actually. These 3 parts weigh about 50kgs or about 110 pounds
After using different bits and sanding roughly down ending at about 320 grit paper I managed to shape them to the shape I desired.
Playing around a bit with some of the parts. That's an ST8 Motherboard tray from a caselabs pc
Huskybongs is offline   Reply With Quote
Old 22nd Feb 2017, 21:43   #2
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Can you resize your images please - the imgur large thumbnail option usually works best.
Thanks
GK
GeorgeK is offline   Reply With Quote
Old 22nd Feb 2017, 21:54   #3
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Aye, massive pics are massive.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 22nd Feb 2017, 23:18   #4
Huskybongs
What's a Dremel?
Thanks
GK
Will do as well as all the previous pictures. My apologies. Ill do it on friday
Old 23rd Feb 2017, 09:36   #5
kim
Multimodder
kim has yet to learn the way of the Dremel
yeah, pics are just giants ones, i thought it was my turn....but lessening scale, i could see pics, and wahooo, i love what you've done...for many reasons, first one, your work on wood and metal is just great, it's gonna be a very beautifull and original compter desk, then, your running x79 chipset like me, and third, I am building a PC-desk myself for several weeks, waiting the right moment to start a thread here, so, I will follow your build with interest...good luck for the following
kim is offline   Reply With Quote
Old 26th Feb 2017, 02:39   #6
Huskybongs
What's a Dremel?
Let's continue then with properly sized pictures
So I contacted Singularity Computers and he luckily agreed to make my design of a dual loop reservoir come to life. The plan was something like this
Then I needed some legs. Used 60mm hollow steel pipe and some 40x40mm steel for the upper bars.
And the mounting for the screenstand was lathed by some shaft steel
Got ze legs in place
And this will be the placement for the screenstand. Mirroring the design of the legs
A very professional way of planning
Wouldn't be a proper desk build unless we had support for 3 screens
We used some 12mm thick steel for this. It's incredibly overkill but it can handle whatever I decide to mount on it
The legs are connected to the frame with 5 x 8 mm bolts (oxygen resistant)
Trying to make the angles "talk to each other" if that makes sense
Testmounting some stuff
Old 26th Feb 2017, 02:41   #7
Huskybongs
What's a Dremel?
Thank you! I've resized the picture to the large thumbnail now as previously requested
Old 26th Feb 2017, 02:56   #8
Huskybongs
What's a Dremel?
Continuation
Had to play around with the parts to see if they fitted properly. They did
Big radiators but they will be completely hidden
Even though it's quite a tight fit
All the major watercooling parts testfitted
Playing around with the fan controller
Got my reservoir back and Singularity Computers also made a video of it. Very very happy with result. It's just fantastic craftsmanship.
Le Video
And on to the interior wood. Now this is actually a pretty long process. But to roughly summarize it:
I had lying around some teak and mahogany plywood and it had been drying up since the mid 1990s so it was just too good to not use for this. I'm just in love with this stuff
Very tedious process of fitting each panel in individually as well as matching the lines perfectly
After several hours all the panels fit.
Had to rework the starboard side a bit
Got a new cover plasmacut from the local workshop
Looking decent
Time to make the holes for the fans and PSU
In order to cut this out a special tool had to be made.
Lathed out room for the fans as well. Despite the desk being really big there's not any extra room to work with
Happy with the result
The starboard side
Fused 3 panels on each side together to get them in and out of the table
Custom PSU mount that also fits 3 ssd's and 2 hdd's
Made a bottom plate for the Reservoir also to mount it more easily
Slowly but surely getting progress
Got some parts back from paint
Old 26th Feb 2017, 03:11   #9
Huskybongs
What's a Dremel?
Time to mount the sidepanels. Had to make incredibly sturdy mounting for this since they weigh so much
From the side
The front
Started with the varnish. Ended up redoing all this but you'll see soon enough
Couldn't cut these at home due to the thickness so went to the local woodshop. They were rather confused when I said it's a pc
Angles worked out fine
Starting to look better
Wanted to get a feel for how it will be to work at this thing
DX racer for scale
Got the hardened glass that I ordered
Rounded corners same radius as the fans
After some work with a CNC I got the sidepanels fixed to have openings for the fans and the fancontroller
Liking the look now
Was a bit worried before I testmounted this whether or not it would line up properly with the interior. Gladly it did
This is not the actual fancovers but wanted to get a feel for how it will look before I drew them up in CAD for the waterjet
From the inside
The nightmare of the top part of the wood To get this to fit properly we had to get all the angles right and shave off half a millimeter at a time until it fit properly. This was a lot harder than I expected but it was worth it
It fits!
And now to the gluing. Using Marine glue here. Takes a long time to harden but it's incredibly strong. Also tapping her up so it doesn't move
Gotta protect the painting
Probably not the best method but it works
After a bit of manhandling it it's finally glued and won't be touched for 2 weeks
Just had to test with the glass on.
Old 26th Feb 2017, 03:25   #10
Huskybongs
What's a Dremel?
The 2 weeks had passed and I put it back on the legs.
Didn't mention it before but the outer shell is actually removable and will remain so if a fan breaks or something like that
All alone in the corner
Reinforced the on some points just to make sure
Time to get those holes needed done
1 Radiator ventiolation hole
and 2 holes + the mountstand hole
Getting closer
That's not how the mountstand will sit. You'll see later
And the glass hole
Yeah, lets do key ignition. No real reason except it would be really cool
Sits pretty well at it's place
Trying to get some harmony with the design. Maybe you think that's jibberish but there's some thought put into this
The glass is finally inside
My friend testsitting it
And the last cavity needed is for the USB, 6.3 mm audio and volume controls etc. Will be using a homemade potentiometer solution here and hiding the DAC/AMP inside the table
Had to continue filling up the glue until there was enough to go sanding
First round of sanding down to 320 grit paper. Will go down to about 2000 eventually
Wasn't completely happy with the interior panels so I actually redid all of them with 8 layers of 2 component diamond mahogany varnish. It's resistant to heat and water so it will have a long life inside
Looks a lot better now
Old 26th Feb 2017, 03:32   #11
Huskybongs
What's a Dremel?
Had to make a solution for getting all of the pieces together so had some long screws that goes through the interior panel and the steel frame and end in the outer panel. These can't be seen unless you're actively looking for them
Mounting solution for the back panel
Back panel fitted
Ordered some more watercooling parts from Highflow
This is what I'll use for audio. The sennheiser hd 650s and and ODAC amp/dac solution from Mayflower Electronics
Had to make custom hinges or we would never get the glass out easily. Will also install electric motors for this so you don't have to do anything else than push a button
Might as well mention this is just prototyping. The actual hinges will be made out of 6mm steel
Instagram filters jk
Made a short video
Started drawing out the design for the fansgrills. I'll get these chromed
Made some longer videos where I go through the build
Lathing out a volume knob
Playing around with the stains
And a video update again
That's it for now will start cablework very soon!
Old 26th Feb 2017, 09:24   #12
storm-83
Supermodder
storm-83's Avatar
storm-83 has yet to learn the way of the Dremel
Wow, that looks gorgeous!
Looking forward to more progress
__________________
storm-83 is offline   Reply With Quote
Old 26th Feb 2017, 22:03   #13
mad_mic3
Multimodder
mad_mic3 has yet to learn the way of the Dremel
The minimalist look of the outside looks sweet as, the inside timber reminds me a 50"s era of wooden speed boat
mad_mic3 is offline   Reply With Quote
Old 26th Feb 2017, 22:33   #14
Huskybongs
What's a Dremel?
Yeah I'm a huge fan of the riva's and bösch boats.
Furthermore my next project after this table is probably a custom runabout boat in mahogany Not that suitable for this forum though
Old 26th Feb 2017, 22:38   #15
voigts
Hypermodder
voigts's Avatar
voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.voigts is a hoopy frood who really knows where their towel is.
I'm not really a huge fan of desk builds in general. Having said that, I have to say that this build is just completely awesome. I can appreciate the amount of time to get this thing looking and working this way. Absolutely excellent work with very appealing styling. I appreciate that your not just after bling, but really spending a lot of blood/sweat/tears on the styling.
__________________
Project Log: Zenith Antique Radio Scratch Build
Project Log: Project Quintessence
voigts is offline   Reply With Quote
Old 26th Feb 2017, 22:45   #16
Hukkel
James' minion
Hukkel's Avatar
Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.
I think I have seen photos of this online somewhere. Maybe social media.
All I can say is that it doesn't even matter that much if someone shares you taste in design. You already have to respect the craftmanship in this. Very well done man. Big respect.
__________________
Facebook page
Hukkel is offline   Reply With Quote
Old 26th Feb 2017, 23:20   #17
Huskybongs
What's a Dremel?
Thank you that's very kind. Yeah I don't love the christmastree-e look of a lot of builds I'm more into the shapes and the less is more mentality. And I just love organic materials
Old 26th Feb 2017, 23:21   #18
Huskybongs
What's a Dremel?
Thank you
Old 27th Feb 2017, 01:16   #19
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Whoah!...DUDE!
Are you kidding? We LOVE this kinda stuff. You could probably post the boat build in 'general' too. there's several car projects in there.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 27th Feb 2017, 17:32   #20
mal
Modder
mal's Avatar
mal has yet to learn the way of the Dremel
What he said.
The craftsmanship and attention to detail in the woodwork speaks volumes. Are you a cabinet maker by trade? Awesome job. I really like when PCs don't look like PCs.
mal
mal is offline   Reply With Quote
Reply
Tags
battlestation, desk build, husky bongs, mahogany, pc desk
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
