Reply
Thread Tools View Mode
Old 22nd Feb 2017, 04:10   #1
Zenator
Multimodder
Zenator's Avatar
Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.Zenator is the Cheesecake. Relix smiles down upon them.
Just a little bit thinner
Hello Again
I had not planed on doing a second build for the world series but I still have time for something small. I have been thinking about doing a small form build for some time
and i've been wanting to do a white build as well, so for this build im looking at doing a build in white and making it slim.
I Will be using a Master Case Maker 5 and a Cosmos SE
De-construccion have begun, lots of cutting still to go to get that "SLIM" look and the MIG waiting to put it all back together again.
Quick layout of parts from both cases.
And a way to put it all back together again, Oh what fun this will be!
Some steel may be injured in this process
__________________
Imagination is just as important as knowledge.
The things I do : http://zenator.wix.com/zenator-art
Zenator is offline   Reply With Quote
Old 22nd Feb 2017, 09:39   #2
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Looking forward to this dude
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 24th Feb 2017, 05:03   #3
FS mods
What's a Dremel?
FS mods has yet to learn the way of the Dremel
Yay welder??? It looks like an overkill lol
FS mods is offline   Reply With Quote
Old 26th Feb 2017, 09:23   #4
Zenator
Multimodder
Zenator's Avatar
Hello again.
Case frame has new been cut down and welded back together, The case is now a 165mm wide, from 240mm wide.
Now with just enough width for the PSU and motherboard.
__________________
Old 26th Feb 2017, 12:29   #5
Vault-Tec
Vault-Tec's Avatar
Are you using the Cosmos shell or the Master case?
I prefer the Cosmos. Still like that case
__________________
MUWC Winner ROTT
Old 26th Feb 2017, 20:11   #6
Zenator
Multimodder
Zenator's Avatar
Going to be using both where I can
__________________
Old 11th Mar 2017, 06:22   #7
Zenator
Multimodder
Zenator's Avatar
Update on the thinner CM build. So Far what i'm doing is im trying to reuse as many parts as I can from both cases. The MoBo tray has been centered in the case to have even room on both sides,
The back side being for the cooling and cabling, Giving me 80mm at the back and 80mm on the MoBo side and a 160mm all up. More then enough space to get things done.
Thanks again for stopping by.
__________________
Old 11th Mar 2017, 16:05   #8
LePhuronn
Multimodder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
Oh my...this is an interesting one!
__________________
Project: ASTERIA II: Rearmoured
In Win 901, case mod, watercooled | Modding update nominee April 2017
LePhuronn is offline   Reply With Quote
Old 11th Mar 2017, 16:33   #9
Vault-Tec
Vault-Tec's Avatar
Wicked, I love me a good wedgie
__________________
MUWC Winner ROTT
Old 19th Mar 2017, 22:41   #10
Zenator
Multimodder
Zenator's Avatar
Update on the Thinner build, Case frame is now reshaped. The back of the case now has room for 2x360 rads for the cooling the GPU & CPU. And inside sits the MaterWatt Maker 1200 PSU. Still lots more to come and still lots more to do.
__________________
Old 19th Mar 2017, 23:38   #11
Zenator
Multimodder
Zenator's Avatar
Some of the very COOL hardware going into the Thinner case.
MAXIMUS VIII HERO ALPHA MoBo W/block, From Bitspower.
ASUS STRIX 980ti And Bitspower RBG W/Block.
__________________
Old 25th Mar 2017, 10:57   #12
Zenator
Multimodder
Zenator's Avatar
Time again to show some pic's.
From one case to the next I have used the rear GPU mount from the Cosmos SE cut it out reshaped it to fit in the top of the frame to hold the GPU in place. Plus one new clear and black printed GPU logo, For some back light RBG.
__________________
Old 10th Apr 2017, 15:20   #13
Zenator
Multimodder
Zenator's Avatar
A bit more to show.
Thinner with a theme.
More soon.
__________________
Old 10th Apr 2017, 15:42   #14
Vault-Tec
Vault-Tec's Avatar
Fluffing hell, that's amazing !
__________________
MUWC Winner ROTT
Old 11th Apr 2017, 10:41   #15
Zenator
Multimodder
Zenator's Avatar
Thanks Vault-Tec
__________________
Old 12th Apr 2017, 14:11   #16
Zenator
Multimodder
Zenator's Avatar
Outer plastic covers now done and a place for the CM badge.
__________________
Old 12th Apr 2017, 14:42   #17
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
I do love seeing people do this to cases, it's a lot of fun to try out. Wide cases are great for ease of building, but when you don't necessarily need it, you can get some awesome looks by going thin. Can't say I'm a huge fan of the GotG covers, but that's your theme so won't be intruding on that haha.
Love how the look has changed so much by removing those extra mms.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 12th Apr 2017, 22:22   #18
Vault-Tec
Vault-Tec's Avatar
Yeah that top that I despise so much has turned into a lovely octagon shape
__________________
MUWC Winner ROTT
Old 14th Apr 2017, 08:34   #19
Zenator
Multimodder
Zenator's Avatar
Happy you like it.
Switchers fitted for a new clean look.
__________________
Old 16th Apr 2017, 08:55   #20
Zenator
Multimodder
Zenator's Avatar
Hi, The color I picked for the build is Harlequin. That will have the same colors as the guardians of the galaxy theme. It still needs to be clear coated as well.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
