Reply
Thread Tools View Mode
Old 28th Feb 2017, 17:41   #1
warboy
Insane modder
warboy's Avatar
warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.warboy is the Cheesecake. Relix smiles down upon them.
CERBERO AK MINI
Hello to all boys and girls
The idea is to create the mini ITX version of my mod called CERBERO
.... now its name is CERBERO AK MINI.
Start thanking
AK INFORMATICA
AQUATUNING
COOLER MASTER
I redesigned the new chassis for mini ITX motherboards and this will have a special painting
The hardware configuration will be:
MOTHERBOARD: MSI Z270I GAMING PRO CARBON ACo
CPU: Intel I7 7700k
RAM: to be defined
VIDEO CARD: ZOTAC GeForceŽ GTX 1070 Mini ZT-P10700G-10M
SSD: to be defined
SSD M.2:to be defined
PSU: Cooler Master V500
FAN: to be defined
The liquid cooling system includes:
CONTROLLER: Phobya Touch 6 Controller - Single Bay 5,25" - black
CPU WB: Alphacool Eisblock XPX CPU - Intel/AMD - silver matte
VIDEO CARD WB: Alphacool NexXxoS GPX - ATI R9 480 M01 - incl. backplate - black
RADIATOR: Alphacool NexXxoS XT45 Full Copper 80mm Triple radiator
PUMP: Alphacool VPP655 - single edition
ADDITIVE: Phobya ZuperZero UV Crystal Blue 1000ml
TUBI: Alphacool HardTube 13/10mm plexi clear
FITTING: Alphacool compression fitting G1/4
RESERVOIR: Alphacool Eisbecher D5 150mm Plexi reservoir
AND MUCH MORE
The Power supply is COOLER MASTER V550 full modular
The motherboard is MSI Z270I GAMING PRO CARBON AC
warboy is offline   Reply With Quote
Old 28th Feb 2017, 19:36   #2
warboy
Insane modder
warboy's Avatar
a new package has arrived for this mod
the liquid cooling system
Old 28th Feb 2017, 19:36   #3
warboy
Insane modder
warboy's Avatar
Here the pump and reservoir for the water coolingsystem of CERBERO AK MINI
Old 19th Mar 2017, 18:00   #4
warboy
Insane modder
warboy's Avatar
Today arrived the processor tested by Roberto Sannino (aka RSANNINO)
Intel i7-7700k @5.0 Ghz
Old 22nd Mar 2017, 19:46   #5
warboy
Insane modder
warboy's Avatar
This is the rad Alphacool NexXxos XT45 80mm TRIPLE with fan COOLERMASTER BC 80 LED FAN !!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
