Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 6th Mar 2017, 19:08   #1
Byron C
This space for rent.
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
SCART to HDMI Converters - Have you used one?
If you have then I'm interested in your feedback. Note, that's SCART to HDMI, not HDMI to SCART (since the latter is a silly idea).
I'm lining up another gaming marathon to raise money for charity, and I'm thinking about doing retro games this time. RGB SCART cables are available for pretty much all the systems that have come to mind so far: SNES, Mega Drive (Genesis... whatever), Atari STe, and Amstrad CPC 464. I refuse to use composite video since the quality is utter garbage compared to SCART, and S-Video isn't really that common (plus I already have a SCART cable for my Atari STe...). Capturing RGB SCART seems to be quite the challenge: the only remotely capable card I've found is £149+VAT (plus a separate adapter cable at £39+VAT) and it's dubious as to whether it's supported in Win10 or even Win7. HDMI capture devices however are ten a penny: therefore converting SCART to HDMI and using one of a multitude of available HDMI capture cards seems to the simplest solution.
My question isn't specifically directed at gaming types: it's perfectly plausible that you might have used one of these devices to keep a beloved piece of A/V equipment compatible with this fancy new HD stuff.
Have you ever used such a box? How did you find the quality of the HD up-scaling? (By that I mean: did it introduce any artifacts or glitches; I know you can't magically add pixels to turn an SD video stream into an HD one.) Did you have any problems using it on your HD TV?
I will probably buy a converter anyway to play around with, since they're cheap, but it'd be good to get an early indication of whether this is going to be a Bad Idea™©.
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 10th Mar 2017, 10:11   #2
Freedom
Hypermodder
Freedom has yet to learn the way of the DremelFreedom has yet to learn the way of the Dremel
Buy a load of old school CRT off ebay you can get them for peanuts for a proper old school gaming experience.
Freedom is offline   Reply With Quote
Old 10th Mar 2017, 10:29   #3
Byron C
Byron C's Avatar
But the problem is that I want to capture the video using a PC, and that's not cheap when it comes to RGB SCART.
__________________
Old 10th Mar 2017, 10:54   #4
Freedom
Hypermodder
hmdi splitter and capture card.
Old 10th Mar 2017, 10:56   #5
Byron C
Byron C's Avatar
Yeah I know. I said that in the OP.
That's why I was asking for opinions from people who have used SCART to HDMI converters. I want to see whether there are any problems involved with the upscaling process.
__________________
Old 10th Mar 2017, 12:21   #6
Freedom
Hypermodder
It all depends on what upscaler your using as to quality.
Old 10th Mar 2017, 12:26   #7
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
Right - I'm going to ramble briefly 'cos I'm busy but I was idly reading this and seem to remember something called an HDFury or something, but I don't recall whether it took an RGB input and upscaled it or indeed if it outputted to HDMI, but it's something to look for.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 10th Mar 2017, 14:39   #8
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
I bought an AV to HDMI converter. Basically I bought a car stereo head unit that I needed to output HDMI because I stupidly did not check the back of my TV (I just assumed it had SCART or some form of AV).
It works OK man. Does get some sort of interference in the form of lines but it's far better than nothing. There are not artefacts or glitches either, just as I say these lines that look like interference.
Which could be caused by something else, due to it being a car head unit.
Pic there. It was about a tenner IIRC.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 10th Mar 2017, 14:58   #9
Byron C
Byron C's Avatar
Thanks guys.
__________________
Old 10th Mar 2017, 23:48   #10
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
Living across the pond I was stuck with Never The Same Colour, and unfamiliar with SCART. If down grading to component video isn't an option have you consider and intermediate step before HDMI and looked at converter to composite?
A quick google turn up the following.
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
