Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 9th Mar 2017, 13:53   #1
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Electrical advice / Bandsaw 'fault'
I've got an old bandsaw which has a bit of an issue. It's nothing fancy, just plugged into a standard 13amp socket.
The basics : The 'on' button on the switch box can only be depressed when there's power to the machine, thats fine. When you power it up it 'hums' when it's not running. You turn it on, you turn it off - all good.
But occasionally the 'hum' won't be there when it's plugged in and the on switch can't be depressed. If you wait a minute or two it'll work again... at least that's how it normally is but the last time I used it I waited a good 10mins or so and couldn't get it to work again so moved onto other things. When it won't run there's no hum from the machine and the on switch has no 'click' to it.
But tested it again today and it worked perfectly. There's the hum when it's powered up but not running and the on switch can be used.
Sound like a motor capacitor issue? I've replaced such things on an old tumble dryer before.
A new capacitor is dirt cheap, so it's an easy test anyway - just thought I'd ask around and see if anyone knew about such things.
https://www.bedfordsaw.co.uk/spare-p...eckum-bandsaws
Guinevere is offline   Reply With Quote
Old 11th Mar 2017, 00:05   #2
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
From your description probably not the capacitor.
Originally Posted by manufacturer's website
...motor starter capacitor... If your bandsaw makes a humming sound and doesn't work when you press the start button, this part may be the cause.
I am guessing that the hum is from the magnetic seal in circuit for the on switch. The absence of the hum suggest there something wrong with the switch mechanism. Hope that helps.
__________________
Wait, Iíve got an idea, and it doesnít require high explosives.
-Sam & Max Hit the Road
Dr. Coin is online now   Reply With Quote
Old 11th Mar 2017, 05:17   #3
srgtherasta
Supermodder
srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.srgtherasta is the Cheesecake. Relix smiles down upon them.
Sounds like the no volt release switch is faulty, replace it there only a few quid off flea bay
srgtherasta is offline   Reply With Quote
Old 16th Mar 2017, 14:14   #4
Guinevere
Mega Mom
Guinevere's Avatar
Thanks guys.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
